6th Gen ('00-'05): 3.4l to L36 swap
Old Apr 30, 2013 | 04:07 PM
Arthur Guice's Avatar
Default 3.4l to L36 swap
Ive bought a totaled Buick Regal, When I complete the swap to my MC am I goin to have to program my vin into the l36 pcm?
Old Apr 30, 2013 | 09:04 PM
My gut says "yes", but honestly, I don't know for sure. Unless you can find the 100% answer, I would approach it this way:
- Perform a PCM Security relearn.
- If that process does not get the car to start, you will probably need the PCM adjusted.
- If you need the VIN added to the PCM and don't need a full tune, I could extend you my services mentioned in the thread below (as I can do more then Montes and Impalas):
https://montecarloforum.com/forum/pr...impalas-42773/
Old May 1, 2013 | 08:28 AM
Thanks Man Can u inbox me your information at stakz225@gmail
Old May 1, 2013 | 11:38 AM
Just bounced you an e-mail. Like I mentioned, not sure if the VIN number needs swapped or not, but if it does, I can do it.
My hope is that a PCM re-learn procedure will get it going, but I honestly don't know without doing more research.
codylewis99
25
Jan 27, 2019 05:18 PM
SpeedForceRacing.TurboTec
Apr 17, 2013 08:20 PM
Deathklox
Apr 2, 2013 09:52 AM
SpaceCowboy
13
May 17, 2012 09:39 PM
sprfrk2005
Aug 8, 2008 04:24 PM
