3.1 engine swap
Old Sep 17, 2011 | 03:23 AM
verirrte's Avatar
Default 3.1 engine swap
I have a 99 Monte ls and the motor is hatched. I have a donor that is an 01 Buick century but its not a direct swap. Anyone know what I will need to change to make the century motor work in the Monte?
Old Sep 17, 2011 | 08:06 PM
nitehawkjcb's Avatar
Depends what engine is in the Century
Probably axles, PCM, wiring harness...IDK if a Century motor will bolt up to your mounts either. I know a Regal motor will FWIW
Old Sep 17, 2011 | 11:49 PM
Basically, keep you Monte's trans (so you don't deal with PCM and axle issues).... Use the Monte's wiring harnesses. You will probably need to swap the motor mount brackets and some sensors.
Only way to know for sure is rip into. If you wanted to up the performance while doing this swap, getting a 3400 to pop in place of a 3100 would be the way to go. The N-body guys have a right up to assist with some of the "need to knows"....
Budsjlm
Apr 3, 2012 05:43 PM
HaRvArDaLe
Nov 3, 2006 08:00 AM
goat
Feb 19, 2006 11:58 PM
batman
Feb 16, 2006 03:18 AM
rchurch
Apr 29, 2005 05:49 PM
