2004 - 3800 Monte SS
Old Jul 2, 2009 | 05:31 PM
InTheBlue's Avatar
Default 2004 - 3800 Monte SS
I am a new member around here but I've been cruising in my black MC for a while now.
I have a Monte Carlo SS - 2004 with a 3800 engine and I would like to add some get up to my performance. The only thing I've done so far is just dropped a K&N air filter in it. It already has 114,000 miles on it but I still love it. I have two twelve inch subs in the trunk so there is a added weight to the rear.
Does anyone have any suggestions for such a high mileage SS? I would prefer it to be as inexpensive as possible but would be able to spend maybe $250 give or take. Thank you for anyones input!
Old Jul 2, 2009 | 05:49 PM
NA or Supercharged?
NA, you could do some ER rockers for that price.
SC, I'd probably go with headers or 1.9 modded stock rockers for that money.
Old Jul 2, 2009 | 06:56 PM
InTheBlue's Avatar
Default NA
NA
Could you send me a nice link of what exactly it is you just said?
Thanks man.
Old Jul 2, 2009 | 07:03 PM
03Monte's Avatar
Originally Posted by InTheBlue
NA
Thanks man.
ER Rockers (NA)- http://www.zzperformance.com/grand_p...=555&catid=104
Modified stock - http://www.zzperformance.com/grand_p...=426&catid=104
Headers - http://www.zzperformance.com/grand_p...=899&catid=110
Old Jul 2, 2009 | 07:16 PM
InTheBlue's Avatar
What about for a little cheaper. Like say a 100 bucks? What could I do where I could see some significant improvement?
Old Jul 2, 2009 | 08:40 PM
03Monte's Avatar
100 bucks, significant improvement?
Maybe $100 bucks worth of racing stickers, there worth 10HP ea.
Old Jul 2, 2009 | 09:16 PM
You can get the ER ratio rocker arms on clubgp.com/forum in the classified section for $200-250 shipped. If you got a set for $200, add on some valve cover gaskets and new bolts- and you're right at $250.
$100 and a significant improvement on a NA 3800 isn't going to happen. Personally, I can barely feel rockers, and those are supposed to add 15 hp.
A couple items I would consider for the ~$100 range- a tuned pcm, a powerlog, a 2.5" downpipe (although if you need a cat, it will be more).
Old Jul 4, 2009 | 03:07 AM
vincenti's Avatar
Old Jul 7, 2009 | 12:25 AM
MonteNoob's Avatar
I have an 04 NA SS love it to death too! Wish it was SC!!! Ok back to the point so when you say you droped in a K&N filter in did you buy an actual intake? For me the Wizair intake from ZZP performance gave it a nice touch.... Or you might want to look into getting a down pipe or ubend delete... Those two tend to help a decent amount on an NA and are not to bad price wise.... Try these sites!
www.wbodystore.com
www.3800performance.com
These sights have helped me tons parts wise. :P)
Old Jul 7, 2009 | 09:16 AM
You aren't going to do much so cheaply. If you wanna make it quicker, seafoam it and take some weight out.
Under $100 isn't going to net you anything unless you make your own fenderwall intake.
Save up $500 and get the basics that's in a sticky for upgrading your engine.
RattPack
16
Dec 30, 2015 04:09 PM
Denarius23
Sep 17, 2014 02:18 AM
golfstud2k4
Sep 29, 2010 03:37 PM
Top_Notch
Feb 8, 2007 01:10 AM
davesbedroom
Dec 24, 2006 03:53 AM
