6th Gen ('00-'05): 2001 monte p1404 please help
Old Oct 3, 2012 | 10:49 PM
01navyss's Avatar
Default 2001 monte p1404 please help
What would cause this code? thank you
Old Oct 3, 2012 | 11:00 PM
Sticky: GM OBD II Trouble Code List
DTC P1404 Exhaust Gas Recirculation (EGR) Closed Position Performance
Old Oct 13, 2012 | 11:35 AM
01navyss's Avatar
Will a new egr valve fix this? I took mine off and cleaned it and the light went off for about a week then came back.
Old Oct 13, 2012 | 12:08 PM
Not if something else is causing your ERG to clog & send a code ? Does your Monte have the factory `Cat ? It could be bad ?
Check back to see what our expert tech's post about your problem...
***Thanks `Chris for posting the Codes & helping a member 4-Sure
Old Oct 19, 2012 | 02:25 PM
01navyss's Avatar
It will go off for a little while when I clear it then come right back
Sliver
FWD Tech Guides '95-'07
Oct 11, 2015 02:52 PM
MJClemm
Aug 1, 2012 12:30 PM
Herlsy
Mar 12, 2012 08:15 AM
MonteSS2001
Sep 28, 2007 06:51 AM
carzam1209
Apr 9, 2007 10:25 AM
