6th Gen ('00-'05): 2001 monte p1404 please help
Sticky: GM OBD II Trouble Code ListDTC P1404 Exhaust Gas Recirculation (EGR) Closed Position Performance
Not if something else is causing your ERG to clog & send a code ? Does your Monte have the factory `Cat ? It could be bad ?
Check back to see what our expert tech's post about your problem...
***Thanks `Chris for posting the Codes & helping a member 4-Sure
It will go off for a little while when I clear it then come right back
MJClemm
Aug 1, 2012 12:30 PM
Herlsy
Mar 12, 2012 08:15 AM
