2000 MC, 3.8 Crankshaft pully won't come off! Bolt is already off!
Old Apr 27, 2009 | 03:51 PM
crete's Avatar
Default 2000 MC, 3.8 Crankshaft pully won't come off! Bolt is already off!
Hello all -
I have a 2000 Monte SS and I need to replace the crankshaft positioning sensor. I was able to get the bolt off with a breaker bar and the starter, but now I can't get the pulley off. It won't budge. I've tried wd40, pulling as hard as I can, hitting it with a rubber mallet, ect..
Anyone know how to get it off? My haynes manual says it doesn't need a puller kit.
Old Apr 27, 2009 | 07:09 PM
04 Intimidator's Avatar
Well dump the WD40 and go for a anti seize lubricant. Try hammer again. then use pulley puller. Just cause it says you don't need one doesn't mean you shouldn't use one.
Old Apr 27, 2009 | 11:47 PM
It lied then...
This is what I used:
http://www.zzperformance.com/grand_p...=339&catid=111
gerolf
May 22, 2015 12:22 PM
erik2282
Apr 27, 2009 04:32 PM
motivation2k3
Sep 4, 2008 07:15 AM
alkalinetri3o
Apr 13, 2008 05:58 PM
livinlow
Mar 22, 2007 08:52 PM
