6th Gen ('00-'05): 2000 3.8 Engine Readouts at Idle
Old Nov 12, 2013 | 11:18 AM
bryan_p88's Avatar
If that code number wasn't correct, I know that the actual code was "Lean Bank 1"
Old Nov 12, 2013 | 11:35 AM
Holy crap I read that completely wrong, I'm sorry
My head wasn't right this morning apparently.
Running that lean, if you can't find a vacuum leak anywhere, check for clogged injectors or a clogging cat.
Old Nov 12, 2013 | 12:54 PM
bryan_p88's Avatar
Thanks, I had thought about replacing all the injectors since they are old and have 282,000 kms on them. I did some more research on the grand prix and impala forums and I am going to recheck everything I've done over the past couple years, just to be safe. I replaced the MAF before I had the OBD2 software so I will start playing with things while keeping an eye on the readings. If anyone has more ideas keep them coming!
Thanks
Old Nov 13, 2013 | 07:48 AM
bryan_p88's Avatar
I read today that the EGR tubes can crack and cause a major, yet hard to find vacuum leak. I'll be checking that tonight.
Old May 6, 2014 | 01:05 PM
Johnlh97's Avatar
Could your vacuum line from your fuel pressure regulator have come off? (something that might be overlooked)
Old May 6, 2014 | 01:44 PM
vikesfan's Avatar
welcome back 6 month old thread!
schmicr
Nov 21, 2014 12:43 PM
el402
Sep 24, 2011 10:58 PM
MonteLu
Oct 12, 2010 04:02 PM
sacclark
Dec 15, 2007 10:37 AM
24_48Fan
Jan 6, 2007 07:47 PM
