1st post. need help
RE: 1st post. need help
yes a 305 will fit any small block chevy will. and big blocks,chevy 90*V6(200,229,262C.I.)will also fit
as for the trans you probley have a th350 or maybe a th400 depending what motor your car came with originaly.
Just wondering? Is the 305 free or an engine you already own?
I ask cause most people consider the 305 nothing more then a boat anchor. If you can, a 350 will be a much better engine for you. More power and more torgue versus a 305.
As for transmission options a 200-4R or 700-R4 will also fit your car. These offer overdrive which will help out on gas mileage. You'll like that. There will be an issue of getting the overdrive to operate properly but there's other owners out there just like you who got this working in their cars. So they can offer help on getting the transmission working right in your car, too.
Just some things to think about.
why would the overdrive not work in his car ? the th200r4 or th700r4 are hydraulicly controled. and the only problem you would have is the lock-up converter and there are a couple of kit avalible to fix that problem.
Cream03Luxury
02-22-2012 07:01 PM
pizzacarlo
11-01-2010 08:36 PM
