1st post. need help
Old Jan 17, 2009 | 02:36 PM
Khanine's Avatar
Default 1st post. need help
I Have A 74 Monte And I Was Wondering Will The 305 Fit
And What Are My Transmission Options
(meaning What Kind Of Transmissions Came With The 74)
Thankz!
Old Jan 17, 2009 | 05:25 PM
88ss408's Avatar
Default RE: 1st post. need help
yes a 305 will fit any small block chevy will. and big blocks,chevy 90*V6(200,229,262C.I.)will also fit
as for the trans you probley have a th350 or maybe a th400 depending what motor your car came with originaly.
Old Jan 17, 2009 | 06:05 PM
rj's Avatar
rj
Just wondering? Is the 305 free or an engine you already own?
I ask cause most people consider the 305 nothing more then a boat anchor. If you can, a 350 will be a much better engine for you. More power and more torgue versus a 305.
As for transmission options a 200-4R or 700-R4 will also fit your car. These offer overdrive which will help out on gas mileage. You'll like that. There will be an issue of getting the overdrive to operate properly but there's other owners out there just like you who got this working in their cars. So they can offer help on getting the transmission working right in your car, too.
Just some things to think about.
Old Jan 17, 2009 | 06:44 PM
88ss408's Avatar
why would the overdrive not work in his car ? the th200r4 or th700r4 are hydraulicly controled. and the only problem you would have is the lock-up converter and there are a couple of kit avalible to fix that problem.
kevinoriega
Feb 26, 2012 11:17 PM
Cream03Luxury
Feb 22, 2012 07:01 PM
pizzacarlo
Nov 1, 2010 08:36 PM
coreyeroc
Aug 31, 2009 05:19 PM
