1987 m.c. s.s.
Old Mar 1, 2019 | 11:01 PM
oldredblackie's Avatar
Default 1987 m.c. s.s.
Hello, need some help with my 87 m.c. s.s. with a 305 engine, apparently it has a feed back or back feed carburator (spelling), my mechanic suggested switching to a different carb. an edelbrock, (hard starts sometimes) which would also involve a different intake manifold, any advice would be welcome. Thanks
Old Mar 2, 2019 | 07:20 AM
Jeffs02rwdSS's Avatar
You can buy a spreadbore carb that will bolt directly to the intake.Good luck
Old Mar 2, 2019 | 01:19 PM
Thanks for reply Jeff, is spread bore a type of carb. or brand name, does edelbrock make one?.
Old Mar 2, 2019 | 08:11 PM
There's usually 2 types of carberator design's a spread bore which has 2 big rear butterflies iand 2 small ones on the front and a square bore which has 4 equal size butterflies . The quadrajet carberator that came stock on your car is a spread bore.
Old Mar 2, 2019 | 09:07 PM
Thanks for the info. Ken
loudNproudSS
13
Aug 7, 2020 12:01 AM
finksta33
Oct 24, 2012 01:03 PM
mcss84
Jul 10, 2012 11:14 PM
1970monte454
Aug 9, 2010 11:36 AM
loudNproudSS
Apr 20, 2008 06:53 AM
