1986 monte carlo surging
Old Aug 29, 2009 | 01:59 PM
monte1986's Avatar
Default 1986 monte carlo surging
I just purchased a 1986 monte carlo with 305 v8, this car is in wonderful condition, all seems perfect accept engine seems to surge and hesitate at a stop light,, and at low speeds seems to like surge in and out, but when you mash on the gas, she is strong.. Maybe someone can tell me what this sounds like please btw, i changed fuel filter, and still problem. any help would be appreciated, thanks
Old Aug 29, 2009 | 02:07 PM
Welcome to our Monte Carlo Family.
For member's to be able to assist in your problem, please post
additional information.
1. How many miles on your 86 Monte ?
2. Is it factory stock without mod's ?
3. How long has it been sitting before you purchased ?
Are you still on your first tank of gas ?
4. Do you have the history on your Monte.
Sounds like it could be your carb...Is it the factory
2bl ?
5. When was the last time it was tuned ?
Plugs/wires/Distributor ?
6. Do you have mechanical skills ?
Look 4ward to your answers & as much infor that
you can post about your Monte...
Oh, we would love to see pictures.
Old Aug 30, 2009 | 03:48 PM
88ss408's Avatar
yeah a little bit more info would be good . but it could be timing related
Old Sep 1, 2009 | 07:45 PM
monte1986's Avatar
thanks for your responces,, i have replaced plugs, wires, cap rotor button, and still has the problem. This car appears to have the quadrajet carb, its 100 % original, and only has 55,000 org miles, it is a really beautiful carlo,, pics are on the way.. Could this be fuel related? jus need some help please thanks
Old Sep 1, 2009 | 08:59 PM
Budsjlm's Avatar
olmost sounds like the torqe converter could be locking up incorectly
Old Sep 1, 2009 | 11:52 PM
TheMonteMan's Avatar
may have a vacuum leak might want to check the lines off the carb.
Old Sep 9, 2009 | 08:28 PM
BlenderHead's Avatar
had same prob with 87 305. mechanic disconnected and plugged some vacuum thingy, EGR valve maybe?? or vacuum advance on dist?? not sure, i'll check it out under my hood and try to get back to you tomorrow. anyway, i havnt had the surging problem since.
Old Sep 10, 2009 | 10:51 AM
Under the hood, removal of the EGR will eliminate surging and increase cruise gas milage at the expense of some increased NOx. Removal of all vacuum lines feeding it will accomplish this.
Old Sep 10, 2009 | 11:14 AM
drewskie043's Avatar
is the carb and distributor stock? if there is a different carb and vacuum advance dist, could the vacuum advance be stuck?
Sparkym
Apr 22, 2015 09:57 PM
peno67
Nov 29, 2014 09:54 PM
monte99
Aug 5, 2010 06:52 PM
jogasz28
14
Oct 30, 2006 11:01 PM
tmnewton1
Feb 5, 2006 06:08 PM
