180 thermo
Old Jan 30, 2006 | 11:38 PM
big green dog's Avatar
Monte Of The Month - July 2005
Default 180 thermo
is there any down side to putting a 180 thermostate in your car ive heard if it gets hot outside sometimes it wont let your a/c work right
Old Jan 31, 2006 | 12:44 AM
fever42's Avatar
Default RE: 180 thermo
HAVE A 180 FOR OVER A YEAR, LIVE IN THE DEEP SOUTH NEVER ANY PROBLEMS
[IMG]local://upfiles/99/874257601B874BC08C756DC567B8E14E.jpg[/IMG]
Old Jan 31, 2006 | 10:26 AM
can2tx's Avatar
I've had mine in since September and there hasn't been any problems, and I live just west of you in Ft. Worth.
Old Feb 6, 2006 | 05:06 AM
z34phoenix's Avatar
the 180's shouldnt have any problems at all. the factory fans will kick on still at 195 or 198 still, but there isnt a big diff in 195 vs 180 so its all good....
if your running a 160... this could cause problems... .cause that is a big diff.... if you are running a 160 you will need to modify the fan turnon points. which means you will need a DHP or some other modified PCM. if you dont have one of these already, then your probably not modded enough to need a 160 stat. and if your asking if you need a 160, then the answer is NO you dont... if you needed one you would know.
Old Feb 25, 2007 | 03:58 AM
thatrealcreolenigg's Avatar
is there any advantanges for running a 180
Old Mar 3, 2007 | 07:15 AM
z34phoenix's Avatar
engine runs closer to its normal operating temp/ ideal operating temp
the cooler the motor the less chance there is for detonation which will destroy your pistons.
$10 is a far price for the extra protection.
Old Mar 15, 2007 | 02:50 AM
04 Intimidator's Avatar
The big negative of running a colder T-Stat is that you loose some fuel economy and over the big picture, loose some life on the engine. I really wouldn't blame any engine problems though on a 180* t-stat. You wouldn't see t-stat probs until around 400,000 miles it is so small.
Old Apr 2, 2007 | 03:00 PM
HaRvArDaLe's Avatar
how much gas mileage will you lose?
Old Apr 2, 2007 | 11:18 PM
In the end probably not enough to complain about. I would guestimate in the end about 0.2 - 0.33 mpg loss.
You will lose more if your tires are underinflated.
Old Apr 3, 2007 | 12:19 AM
z34phoenix's Avatar
but some chips require a 180* and are tuned for one... so without it your loosing mpg.... also the big reason for runing the stat is to cool the engine to lower risk of Knock... when the car sees knock it pulls timing and in some cases enrichens fuel. this will hurt mpg much more... i know from the computer files on my 3.4L a 10* drop in temp only raises the AF ratio .1th of a point! i dont have my laptop i use for tuning here or i would pull up a GTP file and show you the af on it. but im sure its pretty close. bottom line when modding its worth having. even if it costs you $.5 a tank! which is pushing it, its worth it to know your not going ot blow the motor because of Knock
John2689
Jun 12, 2016 08:15 PM
Cowboy6622
Mar 9, 2015 09:03 PM
my00monte
21
Feb 1, 2011 08:03 AM
batman
Jun 9, 2006 05:52 PM
04MonteLS
Jun 6, 2005 11:25 PM
