06 3.5L- Low Oil Pressure Turn Engine Off
Yesterday while driving my Monte on the Hwy, I get a chime, and a message that says "Low Oil Pressure Turn Engine Off," with the red oil light. All of this happens and goes away within a 2-3 second window (I barely had time to read the whole message). Of course I pull over quick, check the oil, only to find that it's full. All appears to be fine and the car is running perfectly fine.
I've done some research online already and it appears to be a common problem with the Impala's (which are the same thing really). Most people are saying it's the oil pressure sensor. So I'm thinking i'll replace it this weekend (the problem has not happened again, but from what i'm reading it gets worse with time).
I'm wondering if anyone here has experienced this problem and what the solution was to fix the problem? I'm hoping it's just the sensor. Nobody seems to actually have pressure problems, but I've read a few post from people saying that sensors, oil changes, engine flushes, you name it, nothing is fixing the problem....that makes me nervous. But the most logical thing sounds to me like the oil pressure sensor and I'll try that this weekend.
Feedback from anyone else that has experienced this problem would be great.
Hi Moderator `Michael,
Sounds like it could `be a bad oil pressure sensor ?
Take your computer to your library & check out
the below links
When completed > Don't 4-get 2 `Flush
www.youtube.com/watch?v=hzT79pVP9jk
YouTube
Oct 4, 2013 - Uploaded by Stephen Rice
This video shows the location of the oil pressure sending unitand how to replace it. You can purchase one of ...
- Check oil pressure sending unit? - Yahoo Answers
https://answers.yahoo.com/question/index?qid...
Mar 29, 2010 - For vehicles with an oil pressure gauge, the sending unit (located ... If this test has little or no effect on the gauge, then your problem is in the ...How would I test a oil pressure sensor if its bad. Mine ...
Nov 1, 2012
Please tell me how would I test my oil pressure sensor if ...
1 answer
Oct 31, 2012
More results from answers.yahoo.com
- How to Test an Oil Pressure Sensor | eHow
www.ehow.com › Cars
How to Test an Oil Pressure Sensor. The oil pressure sensor, often referred to as the oil pressure sender, is a unit responsible for telling a vehicle's computer the ...
- Sending Units | Oil Pressure Sending Unit - AutoZone
www.autozone.com/.../SENDING-UNITS/Oil-Pressure-Sendin...
AutoZone
TESTING. Gauge Check. Detach the oil pressure gauge unit electrical connector. Use a suitable test light (12V-3.4W) to ground the harness side connector.
- How to Test an Oil Pressure Sensor? - Ask.com
www.ask.com › Q&A › Automotive › Vehicle Maintenance
Oil pressure sensor is used to measure the veracity of the engine lubrication system. To test an oil pressure sensor, ensure that the engine is not running and.
I had to change the oil pressure switch on my dad's 08 impala for that issue (bit his low pressure warning was active until I replaced the switch).
It's not hard but gm changed it's location from the previous gens of that block (being the 3100 and 3400).
I only did one of these. I found if you can get the connector popped off, get a oil pressure socket and a long extension, slide it behind the front exhaust mani over to the sensor, spin it off and remove it. When you load the new one in the socket, spin it on by hand (using the extension) and then snug with the ratchet.
I think it took me an hour to do.
I am afraid this may be in the future on our 08imp got the same message a few weeks ago stoped checked it all was well hasn't been back since
Yea, I've read that this is an extremely common problem on this generation Impala/ Monte. Mine hasn't come back on either and I've put 300 miles on the car since the light came on that one time. But the part is $29.99 at Autozone and seems to be pretty easy to replace, so I'm just going to replace my sensor this weekend and change the oil while I'm at it.
Over the weekend I changed out the Oil Pressure Sensor and changed my oil. Problem appears to be solved, no light. Time will tell if it's solved for sure, but I'm thinking it is.
The sensor replacement was pretty easy and took less than an hour. Taking the exhaust manifold shield off and getting a long extension with 27MM Deep Socket is the way to go. A little tricky getting the new one in, but with a little patience and feeling around, it's manageable. One serious note to anyone out there that tries this repair themselves: DISCONNECT the battery first. I did not and shorted the lead on the starter motor against the socket, sparks flying and made a weld mark on my socket. LOL. Lucky for me, nothing other than the mark on my socket, got damaged. Lesson learned, disconnect the battery. LOL
