Can I fit a 502 BB in a 1970 Monte Carlo BB?
Old Jan 21, 2007 | 02:06 AM
Lord_Hate's Avatar
Default Can I fit a 502 BB in a 1970 Monte Carlo BB?
Old Jan 21, 2007 | 02:21 AM
97silverls's Avatar
Default RE: Can I fit a 502 BB in a 1970 Monte Carlo BB?
you can fit any motor in any car with the right amount of mone time and patience
Old Jan 21, 2007 | 06:51 AM
mickey's Avatar
the 70 monecarlos came with a bigg block option with the 454 motors in them, they also had the 4 speed option but are rare as a true production car.
So to answer your question. YEAH!! 502? the blower will fit on top of it and you could almost still shut the hood LOL
also if you have a 70 monte that was a big block you migh thave a transplant unles syou have run the numbers i have actually seen where folks took the BB out for a SM.
the one i had was pretty quick for what it was with a 350 out of a old vet. in it.
but i have seen some with a BB
good luck and keep us updated
Old Jan 21, 2007 | 10:10 AM
88ss408's Avatar
any car that came with a small block can put a big block no problem you dont even have to change anything the motor mounts are the same the transmission fits you will have to mod. the exhaust tho so i guess you have to change somthing but overall its eazy i did it a couple of times
Old Jan 21, 2007 | 12:35 PM
mickey's Avatar
dont forget to replace the front springs out with a stiffer version. other wise it will tend to bottom out the front end on ya also.
but seriously it is not difficult.
Old Jan 21, 2007 | 07:09 PM
You sure can, I saw a couple of 70 Chevells with the 502! So yes!!!
Old Jan 21, 2007 | 07:53 PM
TrickRacin's Avatar
The only other thing I have seen on some older Monte's is that ya might have to check into the power brake booster being really close to the valve cover. I don't know for sure if it will be an issue on a 70 or not but I would keep a close eye on it when your setting the motor in. Other than that like everyone said, it will fit with minor troubles.
Dec 30, 2011 08:38 AM
irocdu
May 18, 2009 11:04 AM
team monte carlo ss
Aug 11, 2008 06:02 PM
MontePython
Jul 28, 2006 05:01 PM
