04 Monte Carlo SS Coolant leak
Old Jul 18, 2011 | 08:28 PM
Jomao_o's Avatar
The mechanic and I fought this til night time, could not get it. Bought the pieces from autozone, the two elbows. As stated above, took the belt off, reservoir off, alt off. But for the life of me/us we could not get the piece in!!!
Old Jul 18, 2011 | 10:47 PM
Did you remove the whole bracket? and I heard it was a Pain to do them.
Old Jul 19, 2011 | 05:13 AM
Jomao_o's Avatar
Maybe that's what was missing.
We just removed the alt. lol
We're going at it after work today.
Old Jul 19, 2011 | 06:51 AM
zipper's Avatar
If you're trying to replace the coolant elbows then you will more then likely have to remove the LIM itself to be able to do it. I can't really think of any other way to do it. It seems like a bit more work, but after you realize that you're actually saving time (and potentially broken parts), then you find out that it's actually one of the most practical ways of doing the job.
Old Jul 19, 2011 | 06:50 PM
Jomao_o's Avatar
He's having a hard time, since he works mostly on foreign cars.
Old Jul 19, 2011 | 06:56 PM
Jomao_o's Avatar
Success! Alt bracket off.
Old Jul 21, 2011 | 09:21 AM
BIGAL131's Avatar
My plastic coolant tubes run through my belt tensioner into the LIM....In the 3.8 without the super charger....the belt tensioner needs to be removed as well as the alternator and bracket and the 2 tubes replaced.Its too bad that GM engineers couldnt use their heads better and route the coolant another way as to NOT use these plastic tubes which just fall apart in time or at least use brass or aluminum tubes to solve this issue!
Old Jul 21, 2011 | 01:12 PM
But BIGAL131 if GM used parts that didn't go bad and never had to be replaced they would go bankru.........nevermind
Old Jul 21, 2011 | 02:36 PM
Jomao_o's Avatar
Lol, switched the parts, in the process broke off a vacuum line "tee"
Old Jul 21, 2011 | 06:48 PM
98Z34's Avatar
Cool
I've done this on my 03 SS and I just did this job last night on my son's 98 Z34 and of all the surprises, the belt tensioner actually has ONE of the elbows as part of the casting of the unit with only ONE plastic elbow tube. I couldn't decide whether to cuss 'em out for only doing one, or bless them for at least casting one of them dam elbows. The stupidest thing of all may be that the replacement parts are plastic so if the engine lasts long enough I may be doing it all over again in 10 years!!!
MonteSquarlo
Dec 16, 2012 06:18 PM
1996Monte_Carlo
Nov 26, 2010 09:52 PM
autonoz
Dec 28, 2006 12:27 AM
orthokneepa
Sep 14, 2006 07:59 PM
greg fell
Jul 19, 2006 10:59 PM
