02 sensor
I know at least 2. How many miles? Plugged fuel filter, plug wires/plugs, PCV Valve, (although that wouldn't really mess with mileage) How new is your air filter, are your tires inflated to the proper PSI? Those are just some ideas other than O2 sensors that would cause bad mileage. Is your car an SS or LS?
i know the one by the cat but figured im getting bad mpg's and it was a 02 sensor how could it do that being all the way by the cat.the 02 sensor on the exaust manifold does make sense to me.i guess i'll have to ask around.thanks
There are 2. One is on the rear exhast manifold directly below the flat part of the firewall.This one measures for air/fuel mixture. The second is about 6 inches behind the cat and makes sure the emissions are good.
The Rev
Oct 19, 2008 09:08 PM
rcohen
Feb 12, 2007 08:49 PM
