02 sensor
Old Mar 18, 2008 | 03:15 AM
jay26's Avatar
Default 02 sensor
how many 02 sensors does a 01 monte have?i been getting bad mpg's and figure that could be one culprit,going to the zone soon so they can diagnostics it
Old Mar 18, 2008 | 03:18 AM
rysZ34's Avatar
Default RE: 02 sensor
I know at least 2. How many miles? Plugged fuel filter, plug wires/plugs, PCV Valve, (although that wouldn't really mess with mileage) How new is your air filter, are your tires inflated to the proper PSI? Those are just some ideas other than O2 sensors that would cause bad mileage. Is your car an SS or LS?
Old Mar 21, 2008 | 06:31 AM
jay26's Avatar
ss,yeah i need to check all those to especially fuel filter
Old Mar 21, 2008 | 06:40 AM
rysZ34's Avatar
At least 2 I know for sure...possibly 3....the two by the catalytic converter and possibly one of the rear exhaust manifold? I'm NOT sure thought.
Old Mar 21, 2008 | 06:59 AM
jay26's Avatar
i know the one by the cat but figured im getting bad mpg's and it was a 02 sensor how could it do that being all the way by the cat.the 02 sensor on the exaust manifold does make sense to me.i guess i'll have to ask around.thanks
Old Mar 21, 2008 | 07:12 AM
dustybird3's Avatar
Photobucket
Monte Of The Month - April 2008
The '02 has 2, one before the cat and one after. If I could find my Haynes manual I could tell you, but since it also covers '01, I'd think it'd bethe same.
Old Mar 21, 2008 | 07:27 AM
jay26's Avatar
thanks!
Old Mar 28, 2008 | 05:13 PM
04 Intimidator's Avatar
There are 2. One is on the rear exhast manifold directly below the flat part of the firewall.This one measures for air/fuel mixture. The second is about 6 inches behind the cat and makes sure the emissions are good.
98Z34
Aug 7, 2011 01:24 PM
FLMONTESS01
Sep 11, 2010 11:47 AM
Endo
Aug 26, 2010 10:16 AM
The Rev
Oct 19, 2008 09:08 PM
rcohen
Feb 12, 2007 08:49 PM
