02 Monte Carlo SS P1441 Code?
Old Sep 28, 2011 | 10:58 AM
ang913's Avatar
Default 02 Monte Carlo SS P1441 Code?
I recently took my car into the shop to have my check engine light checked out and i got a P1441 code. i googled it and it has something to do with the fuel system. I had a fuel system flush and my fuel filter replaced which seemed to stop problems for a while. Its now getting problems again. It starts ok after a while of it bieng off but other times it will sputter, start, and the rpms will fluctuate and it will eventually just shut off and my wheel will lock. Does anybody know what the problem could be? if it helps at all, the last few times ive filled up my tank when i get in my car to start it, it will sputter and start smoking
Old Sep 28, 2011 | 11:47 AM
EVAP system is a pain. You'll have to check all the hoses for one that is not-connected or maybe dry rotted?
If it's not the hoses the purge solenoid is probably shot and telling the car to open when the PCM isn't telling it to
Old Sep 28, 2011 | 12:07 PM
ang913's Avatar
Ya im gonna take it in the shop sometime soon. I just wanted to go in with some background info and possible problems so they dont fix something that doesnt need to be fixed haha. its really annoying to drive because im afraid itll just shut down on me
Old Sep 28, 2011 | 01:10 PM
EVAP system shouldn't harm your performance, or your engine in anyway. Only your MPGs.
Old Sep 29, 2011 | 10:26 PM
ang913's Avatar
Ya but I'm only worried because its shut off on me before while I was driving, luckily both times in parking lots so I kind of wanted to get it fixed before it leaves me at a light. I was recommended a new fuel pump though. Would that help? And how much would that cost me?
Old Sep 30, 2011 | 08:02 AM
When you say it shut off on you.
Were you driving, parked, went into a store, came out to a still warm car and then when you started it wouldn't start? Or it started and the RPMs slowly dropped and it stalled?
I would look into cleaning your MAF and making sure your IAC isn't clogged up with carbon. (Both on the Throttle body, and probably need a security torx 20 bit)
Old Oct 2, 2011 | 12:01 AM
ang913's Avatar
I was driving about 2 miles, turned into a parking lot and it stalled on me while I was pulling into a spot. Other times I started it warm and it jumps to 1500 rpms then slowly falls to a stall
Old Oct 2, 2011 | 02:35 AM
nitehawkjcb's Avatar
Unplug the MAF sensor when it happens, if the MAF is bad, the car won't shut off. It won't run good, but it will run.
x2 on the IAC
hndygrl
Jul 1, 2015 04:22 AM
el402
May 10, 2012 03:58 PM
ownedbypugs
Mar 21, 2012 01:08 AM
TheFrayed
Nov 13, 2010 04:55 AM
RIP86MonteSS
Jun 18, 2010 08:39 AM
