WHAT THE F......
WHAT THE F......
Ok, I bought the best of the Best Terry Cloth Towels, like $12 to $14 a towel. I cut all the edges off, I wash in hot water, rinsed in cold and tumble dry them by themselve. I thensnap them a few times make them soft.
I washed the car, then used a high speed orbitor with cleaner polish, then NXT tech. It looked great. To finish it, I took out one of my towels and with Quick Detail, I sprayed a spot and wipe it off and then notice a thousand very fine scratches. What the HECK?
RE: WHAT THE F......
No... I am very carful. I do everything in small sections, and analyze my work. That is why these scratches are limited to just the top of my rear quater panel.
They are very fine. A wax cleaner will remove them, but how does a freshly cleaned towel (100% cotton loop, 100% cotton backing, high thread count) scratch
I got that same problem .... These manufactures clam that their cloths won't scratch, etc. but I highly doubt it's true ... Then again my car was a used car so who knows what it's been through even before I got it ... I find a new group of scratches everytime I wash my car ... Black shows everything and is very unforgiving i think
While I will agree that black shows alot, I will also point out that WE are our biggest critics. Most people don't see your little scratches that only you know are on your left side quarter panel. Or those little scratches on your hood. Not to mention that a local touch up by a pro shouldn't cost you more than 500 bucks. I personally plan on having alot of mine touched up next spring, after the harshness of winter is over. I feel for you, but realize that you are probably the ONLY person noticing all of those little tiny scratches... The rest of the people in your area are in AWE of the awesomeness of a black SS.
-Keegan
-Keegan
guys in our detail shop are runnin foam pads only for buff/polish/waxing nowdays and only clean em up with 3m wax rags. i hear the best buff job isa 4 step process, first a wool pad, and then 3 stages of foam pads, each softer than the last... of course thats alot of work, so no car through our shop ever gets more than a bad spot ran through 4 steps... more often its either just a wax, or the finish buffing foam pad anda wax.
Guest
Posts: n/a
ORIGINAL: Twisted_Metal
I swore I'd never own a black car ... except, my '76 MC Landau was one of those "can't pass up" deals, despite it being black....
Cort:33swm."Mr Monte Carlo.Mr Road Trip".pig valve.pacemaker
WRMNshowcase.lego.HO.model.MCs.RT.CHD = http://www.chevyasylum.com/cort
"A concrete fascination scraping the edge of nothing" ... White Zombie ... 'Black Sunshine'
with black you have to be very careful which clothes you pick, anything will leave little marks in black...you will find a good cloth one of these days, but its just trial and error, personally i've had very good luck with the 3m ones been using them for about 6-7 years
