Over waxing?
Old May 22, 2010 | 09:26 PM
irulesoha's Avatar
Default Over waxing?
Is there such a thing?
I use a do it your self car was here, and the water is really hard and leaves a lot of spots. I usually wax these off.
So, can I wax too much?
I usually use the Tech 2.0 or the Zymol.
Old May 22, 2010 | 10:00 PM
You can get wax buildup if you wax it too much. It would be especially noticeable on a dark colored car. It's not hurting anything, but it won't look so good.
Old May 23, 2010 | 09:11 AM
JAFO's Avatar
A quick detail spray would probably do the same thing if your concerned about build up. I use a glaze (Klasse) and actually the more layers you put on the better it looks. I've had up to 5 layers on my truck (it's indigo blue) and thought it looked incredible! Heard the same is true for Zaino. I'm sure one of our professional detailers will be in here soon to set us all straight.
Old May 24, 2010 | 12:01 AM
jaws2008's Avatar
GOT SPL
More than 2 layers of Wax wont do anything extra to the paint. often as you get to 4 or more the paint actually seems to look worse do to wax buildup as someone already pointed out.
I prefer the looks of applying a synthetic sealant and than follow with a layer of good carnauba wax and thats about all you need and it looks and protects fantastic
Old May 24, 2010 | 12:11 AM
04MonteLS's Avatar
Zymol is a cleaner wax so rest assured that you aren't layering it cause the following coat will remove the previous one since it's got cleaners in it. Most waxes have cleaning agents in them, the one's that don't generally aren't OTC products so i'm sure you're ok there.
Old May 24, 2010 | 06:24 PM
gothkid's Avatar
Like said above im sure your ok but id switch to a quick wax over a hard wax because the quick wax is designed for inbetween buff and waxes. B4 every car show id quick wax my car
Here i quick wax the red car behind the women b4 the pucture
Old May 24, 2010 | 09:35 PM
04MonteLS's Avatar
Either way, doesn't matter
East
Jan 18, 2010 09:05 PM
Vailliant402
Sep 10, 2009 12:11 AM
vipermann114
Mar 18, 2007 08:55 PM
Nix_SS
Oct 10, 2006 02:14 AM
Great White North
Aug 23, 2006 07:59 PM
