Outside Molding!
RE: Outside Molding!
Hi Member `Sacclark,
Go to your local auto parts store & get some
3M Molding adhesive, or similar auto molding adhesives.
The directions will be on the product.
What type is your black emblem adhesive ?
3M has a adhesive tape that works great.
Good Luck, `Space
[align=center]I would clean the old adhesive, before applying.[/align][align=center]Check temperture requirements before application.[/align][align=center]3M also has a two side tape that works well.[/align][align=center]With the tube you have to be careful not to[/align][align=center]use to much product. Good Luck![/align][align=center][:-]
Plastic Adhesives
High strength adhesives for bonding plastics, such as ABS, Acrylic and PVC, as well as vinyls, fabrics, rigid foams, and many other substrates. Application methods include spray, brush or flow. ...
3M General Purpose Adhesive Cleaner
Specially blended solvent which provides easy cleanup of most types of adhesives, bugs, greases and oils, overspray, silicone, waxes and tars. ...
[:-]Source below [:-][/align][align=center]http://storeapps.net/search/3MeStore...ding+adhesives [/align]
Plastic Adhesives
shovelhead pete
02-10-2011 12:17 PM
Link
03-13-2010 01:36 PM
Joe Bloggs
11-26-2009 12:20 PM
