Outside Molding!
Old Feb 8, 2008 | 03:43 PM
sacclark's Avatar
Default Outside Molding!
My '95 Carlo's outer door trim is coming off and it looks like CRAP! HOW DO I REATTACH IT? I was just going to use black emblem adhesive, would that work?
Old Feb 8, 2008 | 04:03 PM
Default RE: Outside Molding!
Hi Member `Sacclark,
Go to your local auto parts store & get some
3M Molding adhesive, or similar auto molding adhesives.
The directions will be on the product.
What type is your black emblem adhesive ?
3M has a adhesive tape that works great.
Good Luck, `Space
Old Feb 8, 2008 | 04:13 PM
sacclark's Avatar
It's 3M, its not a tape, but a tube.
Old Feb 8, 2008 | 04:26 PM
[align=center]I would clean the old adhesive, before applying.[/align][align=center]Check temperture requirements before application.[/align][align=center]3M also has a two side tape that works well.[/align][align=center]With the tube you have to be careful not to[/align][align=center]use to much product. Good Luck![/align][align=center][:-]
Plastic Adhesives
High strength adhesives for bonding plastics, such as ABS, Acrylic and PVC, as well as vinyls, fabrics, rigid foams, and many other substrates. Application methods include spray, brush or flow. ...
3M General Purpose Adhesive Cleaner
Specially blended solvent which provides easy cleanup of most types of adhesives, bugs, greases and oils, overspray, silicone, waxes and tars. ...
[:-]Source below [:-][/align][align=center]http://storeapps.net/search/3MeStore...ding+adhesives [/align]
Old Feb 8, 2008 | 04:39 PM
sacclark's Avatar
Thank You, Just wanted to make sure i was not going to mess up the poor thing.
Old Feb 8, 2008 | 04:43 PM
Cully77's Avatar
Monte Of The Month -- May 2011
Remove it!
shovelhead pete
Feb 10, 2011 12:17 PM
Link
Mar 13, 2010 01:36 PM
Joe Bloggs
Nov 26, 2009 12:20 PM
cali2000ss
Sep 13, 2008 11:27 PM
BeachBumMike
Aug 4, 2007 04:21 AM
