Opti-Seal
Old Apr 15, 2015 | 05:53 PM
tweek's Avatar
Default Opti-Seal
Anyone use Opti-Seal sealant? The stuff is amazing. it literally only takes 10 min to do an entire car. and the car is soo smooth when you are done. I went to a car show last night and my car had one of the highest gloss finishes there but was hands down the smoothest. I would highly recommend this to everyone. Plus if you claybar before you use it like I did then its extra smooth. Im a big fan of smooth paint finishes. Gotta protect the paint.
Old Apr 15, 2015 | 06:55 PM
Question Member's > HAve U used the below ? >Let us know `OK<
Hi `Tweek,
Thanks for your post & review...I've never used it & didn't know what it was ? Found the below online (Is this it ?)
Optimum Opti-Seal 8 oz. Free Bonus! New & Improved!
Free with purchase of Optimum Opti-Seal you will receive 4 free poly foam applicators. Retail Value of $7.96.
Incredible shine, slickness, and value!
The latest Optimum Opti-Seal formula offers greater slickness and protection!
Optimum Opti-Seal is a revolutionary paint protection formula that creates unmatched slickness and gloss with just a few drops per vehicle. One ounce completely seals and protects 4-5 cars! This product leaves no residue and requires no buffing. Enjoy months of durable polymer protection with just drops of Opti-Seal.
Optimum Opti-Seal is a true paint sealant with no cleaning properties. It seals and protects paint under a crystal clear barrier of cross-linked polymers. Dirt, moisture, oil, and UV radiation are all sealed out of the paint to maintain optimum gloss. It is a spray sealant that provides the durability of a wipe-on sealant and the ease of application of a quick detailer. But it is not a hybrid of the two – Opti-Seal is a new type of product that seals and protects using just drops per vehicle!
The science behind Opti-Seal is incredible. The hyper concentrated polymer sealant begins cross-linking as soon as it hits the paint. Opti-Seal flashes almost immediately to leave a thin polymer film on the paint.
Opti-Seal is not a short-cut product. It is a state-of-the-art, stand-alone spray sealant that provides real, durable protection for paint, plastic trim, and wheels. This is a last step product, not a maintenance product. After polishing, apply Opti-Seal and walk away. Opti-Seal is the only paint protection your vehicle needs.
Opti-Seal is crystal clear in the bottle and on the paint. Applied very thinly, it will not streak or cloud. Simply spray, wipe, and walk away. Opti-Seal leaves absolutely no residue to buff off. It couldn’t be easier!
Preparation is the key to achieving the optimum gloss with Opti-Seal. There are no fillers or cleaners. This is a true paint sealant. If your vehicle has some light imperfections, use Optimum Poli-Seal, their one step polish and wax. Poli-Seal will remove mild swirls and oxidation. Top the smooth, shiny finish with Opti-Seal for added protection and gloss. Opti-Seal can also be used as a base coat under a carnauba wax.
This value is unbeatable! Think about the cost per ounce ratio of Opti-Seal. What other paint sealant treats 40 vehicles with just 8 ounces?! Professional detailers and anyone who wants long-lasting results will love Optimum Opti-Seal.
In the final analysis, Optimum Opti-Seal is unbelievably easy to apply, provides excellent durability, impressive water-beading, and great looks.
Application tips:
  1. Use very sparingly. Opti-Seal is made to be applied in a thin layer.
  2. Always use a clean, soft applicator to spread Opti-Seal over your vehicle.
  3. Prep the paint before applying Opti-Seal. Remove any swirls or imperfections beforehand because Opti-Seal is a true paint sealant with no cleaners or fillers.
8 oz.
Optimum Opti-Seal 8 oz. Free Bonus! New & Improved!Item #:OPT-SEALOur Price: $24.99Availability:Usually ships the same business dayEnter Quantity:
Old Apr 15, 2015 | 07:45 PM
tweek's Avatar
Yes that is it
Old Apr 15, 2015 | 08:00 PM
ohara's Avatar
Definitely willing to give that a try
Budsjlm
RWD Tech Guides '70-'88
Jan 21, 2010 09:25 PM
Nuffy
Mar 29, 2009 11:05 PM
Darkness98
Jun 11, 2008 05:41 PM
rj
Apr 17, 2008 11:53 AM
mickey
Jan 22, 2007 05:52 AM
