mildew smell
Old Apr 3, 2008 | 12:59 AM
cali2000ss's Avatar
Default mildew smell
I get this mildew smell from my vents after using my a/c. Is there anything I can do or buy to get rid of this problem ?[/align]
Old Apr 3, 2008 | 05:28 AM
Default RE: mildew smell
[align=center]Hi `Joe,[/align][align=center]Check Out the below links.[/align][align=center]I hope it helps....Good Luck, `Space[/align][align=center][/align][align=center][/align][align=center][:-][/align][center]how do i get the smell of mold out of my car? i think it is ...
If the mildew smell remains in your air conditioning vents, try an odor- .... "How do I get the cigarette smoke smell out of my car from the previous owner? ...
askville.amazon.com/smell-mold-car-coming-air-ve... - 310k - Similar pages
http://askville.amazon.com/smell-mol...questId=182151
How To Remove Mildew Odors from a Car | eHow.com
If the mildew smell remains in your air conditioning vents, try an odor- or ... I've used it in my bathtub, concrete driveway, and in the basement. ...
www.ehow.com/how_155767_remove-mildew-odors.html - 70k - Similar pages
http://www.ehow.com/how_155767_remove-mildew-odors.html
Why does my car air conditioner smell like vinegar!!!! or .....
"Why does [b]my car air conditioner smell[/
Old Apr 3, 2008 | 12:20 PM
GrandPaDave's Avatar
Yeap, running fresh keeps the mold from building, but in SoCal, when you run fresh, you get all the smells of the city in your cabin....YEEEECHHHH.
I like to spray air freshener with ordor-killer or anti-bacteria and mold feature into the bottom intakes by your toes and keep it on recirculate.
You can also run your vents for a couple of minutes after using recirculate, that usually helps a bit.
Old Apr 3, 2008 | 06:46 PM
mickey's Avatar
belive it or not G.M. has a write up on this for certin years in teh montes and the grand ams i think it was.
what happens is the condesation gets in to the system and you cant get it out with out putting a dryer in to the system and then vac. down the system. then you can put a can of the RIGHT spray in the car and it will get rid of the smell also.
but the other thing to do is change the incabin filter on the car and this will help you some.
And if you know a insent or a x-mass tree air freshner you really like
pull the incabin filter out.
now take your favorit smell good stuff. and cut it in to small strips (if not already small enough)
Now stick them in the folds of the new filter and then you can enjoy the stink for a while with out the mildew stink also.
I knwo they have a kit for this threw the dealer also it has a external Air Dryer in it to stop it from happening agian.
03SSLE
May 20, 2015 03:16 PM
ffriccio
Jul 1, 2007 09:06 PM
24_48Fan
Nov 28, 2006 08:25 PM
Scott 41
Oct 21, 2006 02:44 PM
dvick01
Jul 28, 2006 07:18 PM
