Kev's 1979 Monte Carlo (frame off project)
Old Apr 2, 2012 | 12:00 PM
  #91
CruizinKev's Avatar
just found out ChevyTalk has posted my project on their facebook-site!
Old Apr 2, 2012 | 12:16 PM
  #92
01 Monte SS's Avatar
Awesome
Old Apr 7, 2012 | 09:32 AM
  #93
CruizinKev's Avatar
thanks
finished headliner insulation today
jeep cherokee steering shaft vs. g-body
blazer spindles, new hubs and kore3 c5 caliper brackets
Old Apr 8, 2012 | 07:06 PM
  #94
03SSLE's Avatar
I don't know how I haven't seen this thread before now, but you are definitely a man with a plan! I look forward to seeing your updates and especially the car once it is finished. Outstanding!
Old Apr 8, 2012 | 07:46 PM
  #95
Jparks's Avatar
WoW this car is going to be a GEM! I'm very jealious I wish I had the know how to build a car, this things is amazing keep it up I can't wait to see it all done
Old Apr 15, 2012 | 03:27 AM
  #96
CruizinKev's Avatar
thanks guys!!
update again
Old Apr 15, 2012 | 03:58 AM
  #97
Very Nice! Looking good
Old Apr 17, 2012 | 09:35 AM
  #98
TheMonteMan's Avatar
what springs did you go with? i havent kept up with youre thread. ive seen people run the moog springs for an s10 with the second gen fbody spindles, and brakes with the hotchkiss or global control arms, but never the blazer spindles. i know with the setup i mentioned it drops the nose a couple of inches, and gives you the bigger brakes. what kind of drop is this set up going to give you and how big of a rotor up front? like i said i havent kept up with this thread too much info to sift through. what rear and rear brake setup are you going with? the build is awesome keep up thegood work.
Old Apr 17, 2012 | 12:57 PM
  #99
CruizinKev's Avatar
thanks man!
those are 2" lowering springs from OPGI. told by other forums that the springs handle kinda like eibachs. my front lower and upper arms will bring the front down another 1". so it'll be like lowered 3" on fronts & 2" on rear.
talked to Tobin @Kore3 and he said the blazer spindles got a better design for the C5 brake upgrade than the stock g-body spindles. the blazer has bolt on hub - the g-body you need to machine a stock rotor down to use it as a hub. there are a few shops you can buy custom g-body hubs but if you can find blazer spindles + hubs (only the 98+, 2-door, 2wd) it'll be a lot easier for the whole upgrade. with the blazer spindels the whole upgrade is like a bolt on - with the stock g-body spindle you need to do a lot of work (metal cuts, drill and tap).
For now I'll use the stock rearend and brakes - but will upgrade with a 8.5" GM or 9" Ford later.
Old Apr 17, 2012 | 06:50 PM
  #100
That is gonna be one nice 3rd gen.
