I Broke this
Old 09-03-2009, 07:30 PM
captaindamnit's Avatar
Default I Broke this
Can anyone show me where to get another one of these? I was fixing one of my speaker wires, and it ended up breaking some of the teeth when I pulled the dash off. It came off a 2000 Monte Carlo.
Old 09-03-2009, 08:27 PM
hey man mine broke too...hope someone can help us...
Old 09-03-2009, 09:16 PM
i'm not sure exactly what is called, but check here http://www.gmpartsdirect.com/
lDescriptionQtyMSRP PriceYour Price Total Cost Mechanical Catalog - 2000 - Chevrolet/Geo - Monte Carlo
, Ignition switch, impala, monte carlo $191.79$99.74 $99.74 looks like it may be expensive, not sure if this is even it ,
but check the site or call! or maybe try online junkyard, goodluck, wish i could help more but this is all i got! see ya
Old 09-03-2009, 09:24 PM
I would try your local chevy dealer. a good parts counter person can find just the plastic piece you need and i'm just guessing but looks like should be fairly cheap 8-10 $.
Old 09-03-2009, 10:26 PM
Taz is offline
I did a search for that part on GMpartsdirect a while back. They only wanted to sell the entire ingition switch with the piece. Which is hugely expensive and un-necessary IMO.
If the junkyards aren't any help, I'd go with Jeff2425's idea. Bring the broken piece with you to the parts counter. There's likely a part number molded right into the plastic. A good parts guy should be able to get the part without the ignition switch.
Old 09-03-2009, 10:30 PM
I'd hit up local parts recycler's, i'm sure if you found one they'd let it go for a couple bucks.
Old 09-03-2009, 10:39 PM
Enzo354's Avatar
STILL SLOW
Old 09-03-2009, 10:41 PM
mine is broke as well, the crappy part about it is the fact the stealership did it when i had the ignition cylinder changed...
they put it back on with some form of glue... i only found it when i was taking my dash out.
Old 09-03-2009, 11:57 PM
lol Enzo354 haha nice. Just posts a picture of super glue lmao priceless. Super glue that bad boy on their...mine came out when I was trying to fix my key (it didn't want to turn). so i just popped it back in.
Old 09-04-2009, 12:13 AM
SILICONE!!! That's what I used to fix mine!!! I'm not even kidding. I took the dash off, lined it up where it's supposed to be and TADA! Holds like a charm, I glued the ignition collar directly to that rubber bit in the little hole where the key goes (you know what I mean) and it sticks. as long as I can get it around the ignition and it stays there, I dont care if it aint supposed to be glued.
Quick Reply: I Broke this
