headlights
Old Dec 4, 2006 | 01:44 PM
turner_dtp's Avatar
Default headlights
my turn signal isnt working anymore in the front..do i have to take the whole left headlight off..or is there a simpler way..any help?? thanks
Old Dec 4, 2006 | 02:05 PM
wiz kidd's Avatar
Default RE: headlights
they're just 2 clips that hold the headlight in, then the whole thing slides out
should be 2 white plastic clips that go downwards...just lift up on them and they should come out and then the headlight will slide out, then just pop it out, might have a rubber cover over where the spot is, i can't remember
Old Dec 6, 2006 | 10:16 PM
jeffsmonte's Avatar
Yeah I replaced all the bulbs in my headlights. All you have to do is pull up on the two white plastic clips behind the headlight assembly. Then disconnect the wiring. The whole thing can be just removed from the car after that.
Old Dec 7, 2006 | 10:28 AM
wiz kidd's Avatar
ORIGINAL: jeffsmonte
yah its like the easiest set up i've ever seen for changing headlights
Old Dec 13, 2006 | 01:01 AM
Yellow_Monte's Avatar
well...actually silverados are easier
Old Dec 13, 2006 | 01:07 AM
rcohen's Avatar
yeah my stupid 9006 bulb went out. so i go to walmart to get new ones, and i find these beauties. Pop the white clip off, and it magically dissapears in my engine bay. Drove around, poked around..nothing fell out. So i need a new ones of those, anyone know where to get em? So than I Go to replace the bulb that isnt lighting, and find the wiring the bulb snaps into is all burnt up. Than I said eff this, put the original back in, and it works! SOOOOO, anyone know where I can get more of those white clips, and what to do about the harness (i assume the bulb will go out again and I need to replace the wiring harness) Thanks guys
Old Dec 16, 2006 | 06:40 PM
turner_dtp's Avatar
thankz..yeah i hadnt paid attention to the clips...but yeah it was the easiest set up once u see it..thanks every1
kyle08
Aug 29, 2006 10:43 PM
mikeyB976
Jan 27, 2006 05:39 PM
ralphtrent
Oct 5, 2005 03:35 PM
big green dog
May 22, 2005 10:42 PM
dagibbo
Dec 12, 2004 09:51 PM
