fog lights?
Old Aug 14, 2006 | 01:36 AM
Puppet Master's Avatar
Default fog lights?
Where can I get fog lights for my 2002 LS? There are just empty spaces where they should be now, and they are hideous. Also, how hard is it to install them?
Old Aug 14, 2006 | 02:05 AM
fever42's Avatar
Default RE: fog lights?
SAW A SET ON EBAY
[IMG]local://upfiles/99/08CB208D6E2444189095E99AA2D072D7.jpg[/IMG]
Old Aug 14, 2006 | 10:28 PM
dickie34's Avatar
i got these at autozone for 20 bucks, i could have mounted them better at first, and im prolly gonna redo them and recess them back further when i get some some. they werent hard to install, i wired up the battery wire to the ignition fuse so they will turn on only when the car is on and put the switch to the right of light ****. the second picture you can kinda see how they are recessed enough, i just screwed them into the plastic right there
[IMG]local://upfiles/1034/2CD135F4121E428CBEF151091EE40FF2.jpg[/IMG]
[IMG]local://upfiles/1034/902B9F63BD9A4EA7B2CA72DF4FBD8089.jpg[/IMG]
Old Aug 15, 2006 | 06:37 PM
mickey's Avatar
i almost like those better then the stock one i have lol
but most of the time if you look you can find the wires that are there for the cars. and if this is the case you can get the switch from one in the bone yard or from teh dealer. and just mount everythign in to place and plug in to the factory wires if you use the stock set up. also you might need to figure out where the fuse is and put one in but i think it is attached to something else that should be on your car.
good luck
rg9johns
Jan 2, 2022 05:51 PM
rg9johns
Aug 22, 2014 10:46 PM
guzzimane
Apr 27, 2014 10:02 AM
dc1
Nov 9, 2013 01:48 AM
mickey
Jun 29, 2005 11:40 AM
