Engine Detailing
Old Oct 6, 2009 | 09:29 PM
Default Engine Detailing
Hey, im just looking for tips on detailing an engine, what to use and how to use it, any help would be great. THANKS
sticky?
Old Oct 6, 2009 | 09:36 PM
Budsjlm's Avatar
i think there may have been one on this befor but may be a different a dif forum me i just go to the car wash(self serve) use there engine cleaner stuff and then spray it down with water
Old Oct 6, 2009 | 09:38 PM
Budsjlm's Avatar
take a microfiber towel and whpe down all with meguires hottire...ot says not to use it on plastic or painted parts but i've been doing it for years no problem...
Old Oct 6, 2009 | 10:08 PM
Enzo354's Avatar
STILL SLOW
Simple green on all non painted parts.
Old Oct 6, 2009 | 10:18 PM
Budsjlm's Avatar
here's an example it's my engine comp in my sl2
Old Oct 6, 2009 | 11:02 PM
Frosty LS1's Avatar
Be very careful on engine detailing, I've never done it before...but from what I've read it is HIGHLY recommended you find some plastic, aluminum foil, or something to cover up all of the electronics and wiring under the hood of the car. If you spray that with water you could cause a short, or if you spray water into the Throttle Body, or air filter, you can ruin your engine. Plastic grocery bags would work, cover all the electronics and wiring with that, THEN you may spray down the engine interior with the de-greaser, let the car sit in the sun, hood up, then take a towel to wipe away what's left.
Old Oct 6, 2009 | 11:15 PM
justin, is that a car you had or still have, i'm again confused??
Old Oct 6, 2009 | 11:22 PM
Budsjlm's Avatar
quatermain all wires in engine compartment should be water tight...if u ever remove on they have a rubber gromet in the conection so that shouldn't be a problem.. i've never had one even with my 85
Old Oct 6, 2009 | 11:23 PM
MAMONTE's Avatar
Like Brock, I use Simple Green...And Like Quatermain said, I cover all my electronics with Aluminum foil, especially the alternator....
Then spray everything down with 100% Simple Green, and hook the hose to the water heater...then I blast down the engine. Turns out really well.
The reason I use hot water, it cleans better...
NEVER clean your engine while it hot with cold water. You could potentially crack your block by spraying super cold water onto a hot engine block.
Also, i've tried the engine cleaners/ degreasers you can buy at the store...they work well, but leave an odor for a long time after that smells like chemicals...and it comes through your vents. I found Simple Green to be much better, and it leaves no odor behind.
Old Oct 6, 2009 | 11:24 PM
Budsjlm's Avatar
and yes if you have a filter like mine i sugest wrapping with a plastic bag...
