Colored Interior Panels
Old 02-24-2010, 06:40 AM
Overdose666's Avatar
Default Colored Interior Panels
Well at the moment im unemployed so i've decided to put some time into make my car a bit nicer. I was wanteing to paint some of the interior panels such as the plastic center console, the part of the dash that must be removed to replace the stereo, the plastic trim around the door handle and lock, and the odd shaped side panels in the back seat that look like they should hold speakers. I was wondering if these need to be professionaly painted, or if i can just throw some spray paint and clear coat em. Anyways heres a pic of the dash kit...
http://overdose666.deviantart.com/ar...nels-155254707
the parts im planning on painting are 1, 2, 3, 4, 6, 7, 8, 15, 16, 17, theres a few other parts im thinkin of doin but it might be a bit overkill.
Let me know what u think
Old 02-24-2010, 07:01 AM
Hi Overdose, check out the below sites Hope they help
Your Morning reading assignment : ) Let us know what you do &
post b-4 & after pic's Good Luck
How to Paint the Interior of Your Car - Associated Content ...
Jun 15, 2006 ... To test how colors will look on the interior of your car, paint samples .... with automotive paints....... i am around automotive paint for ...
www.associatedcontent.com/.../how_to_paint_the_interior_of_your_car.html - Cached - Similar
Everything Auto: Dash Painting | Extreme How To, DIY - Do it ...
Everything Auto: Dash Painting Steve Temple. Even if your car's interior isn't showing ... Use a scouring pad and a paint-prep gel to rough up the surface, ...
www.extremehowto.com/xh/article.asp?article_id=60317 - Cached - Similar
Do it yourself auto repair: can you paint a car interior?
How to fix and paint fading or cracking paint, plastic, vinyl and leather in the interior of old cars or trucks, including fabric on the seats.
www.essortment.com › Do It Yourself - Cached - Similar
Vinyl Car Interior Paint and Styling Spray
Remember, G2 Car Interior Paint and Styling Spray offers specially formulated spray dyes for automotive and aircraft interiors to get you the best results. ...
www.streetbeatcustoms.com/incarstyl.html - Cached - Similar
How to paint car's interior - Fix-it Forum: Home Improvement & Do ...
How do I paint the interior of my car? by Ryan 12/8/03 11:31 PM ... auto interior by David 2/12/03 11:12 PM ...
www.bobvila.com › Ask a QuestionFix It Forum - Cached - Similar
DuPont Automotive: Paint & Coatings for Interior
Automotive. Paint & Coatings for Interior. Requirements. For surfaces of vehicle interiors which are often touched, soft touch coatings applied to these ...
www2.dupont.com/Automotive/.../paintCoatings/interior.html - Cached - Similar
video how to paint a couch sofa or car interior with spraypaint
How to stencil a t-shirt · how to make an American flag shirt video · How to spray paint a sofa couch video · how to spray paint a car auto interior video ...
sunshinejoy.com/default.asp?Category=16&MenuItem... - Cached - Similar
Old 02-24-2010, 09:09 AM
skylark65's Avatar
if your gonna paint the interior plastic panels i would wanna sand the finish down very well, otherwise the paint will flake right off. and plenty of clearcoat. you probibly also want to use some adheishion promotor.
Old 02-24-2010, 09:38 AM
Thanks for the quick replies guys, the links were really in depth and helpful.
I'll be starting this weekend and I'll definitely post some pics for ya.
Old 02-24-2010, 08:16 PM
krylon fusion is made for plastic if u can find the color your lookin for. maybe a lil cheaper than getting something mixed
Old 02-25-2010, 04:54 AM
I used Fusion for my engine cover, but it doesn't get the "wear" that interior pieces do. Might try searching around on the sight I know there is a silver Monte on here that has pretty extensive paint on the inside. IIRC he had a thread about what he did, or at least described it in someone elses thread. Would have thought by now he would have chimed in that's why I didn't mention it earlier.
Old 02-25-2010, 08:23 AM
I am definetely looking forward to the pics, as I have been thinging about painting some of my interior panels gray. I like black, but there might be a bit too much in the monte.
How do you plan on removing the "rubber" coating on some of the pieces?
Old 02-25-2010, 08:49 AM
Can't wait to see how your 7/8 comes out
I have an extra set of those in a closet waiting for paint.
Old 02-25-2010, 11:38 AM
Good luck! Let me know how it goes, I was thinking of doing something similar.
Old 02-25-2010, 11:44 AM
I have use krylon fusion and it turned out great. Just a lil sanding, a lil wet sanding and 3 cotes and its all good.
Tips: to consider
use 400 grit sandpaper, (any less and you will score it)
wet sand 400 to 800 inbetween cotes
apply wax now and then to give it a nice shine (dont press hard)
Krylon fusion does not need a clear cote but the do make them, and if you using real paint you will need a plastic primer and clear cote.
For thoes thinkin about tinting, the passenger door window is tinted @ 35%.
Quick Reply: Colored Interior Panels
