~> Detailing `Sping 2009
yeah that is the exact product that i got. can you give me any advice as far as the best way to use it? this will be my first experiance with this product. i plan on a wash then clay bar then wax...i hope this is right?
Click above link & if it doesn't connect,
click below source link
Removing above surface bonded contaminants and restoring a smooth surface to your paint finish is easily accomplished by using Meguiar’s® Smooth Surface® Clay Kit. Our non-abrasive clay bar safely, easily and instantly removes bonded contaminants as you rub it across the surface of your car using a mist & wipe product, like Meguiar’s Quik Detailer® as a lubricant. Meguiar’s Smooth Surface Clay Kit contains everything you need to create a smooth surface! Clay Kit includes: two 50 gram clay bars, individually wrapped & in a moisture-seal case, Quik Detailer for use as a clay lubricant, Cleaner Wax sample & Meguiar’s Supreme Shine® Microfiber Towel.
http://www.meguiarsdirect.com/product_detail.asp?T1=MEG+G1016
Source link above
BeachBumMike
Mar 4, 2008 06:59 AM
Good Luck, post b-4 & after pic's
