Racing your Monte Raced a guy in your ride? Had that Monte Carlo of yours on the timed track? Tell your story here.
6th Gen ('00-'05): 3rd gear
Old 07-03-2015, 11:19 AM
domo_smash's Avatar
Default 3rd gear
I was reading on a tread when racing your MC you want to put it n 3rd I was wondering why is this
Old 07-03-2015, 01:52 PM
4th gear tends to be on the weak side so its best to not go into it at full throttle.
Old 07-03-2015, 01:58 PM
domo_smash's Avatar
Ok so why 3rd and not drive
Old 07-03-2015, 03:07 PM
Leaving it in 3rd prevents the car from going into 4th gear. It'll shift through all the gears and stop at 3rd.
Old 07-03-2015, 03:10 PM
domo_smash's Avatar
Aww ok thanks
Old 07-04-2015, 07:44 AM
turbo monte's Avatar
Leprechaun is correct. Stay out of 4th under WOT!
Old 07-11-2015, 10:06 PM
plumbob's Avatar
Didn't they improve (harden) the shaft on the 4th gear clutch hub in midyear '03 and later models?
Are there other problems with 4th gear?
Old 07-13-2015, 12:25 AM
I believe the problem is as Turbo Monte said on a different post is the 4th gear clutch packs won't stand all the pressure / friction and they are the components which fail, not the shaft breaking.
When racing I start in 1st and shift up to 2nd and finally 3rd.
Old 07-13-2015, 08:33 AM
Zippy is correct. It's the 4th clutch packs that will be toast very fast when making decent power and in 4th gear
Old 07-13-2015, 09:16 PM
plumbob's Avatar
Thanks guys. Good to know.
Quick Reply: 6th Gen ('00-'05): 3rd gear
