3rd gear
I was reading on a tread when racing your MC you want to put it n 3rd I was wondering why is this
4th gear tends to be on the weak side so its best to not go into it at full throttle.
Ok so why 3rd and not drive
Leaving it in 3rd prevents the car from going into 4th gear. It'll shift through all the gears and stop at 3rd.
Aww ok thanks
Leprechaun is correct. Stay out of 4th under WOT!
Didn't they improve (harden) the shaft on the 4th gear clutch hub in midyear '03 and later models?
Are there other problems with 4th gear? |
Originally Posted by plumbob
(Post 667675)
Are there other problems with 4th gear? When racing I start in 1st and shift up to 2nd and finally 3rd. |
Zippy is correct. It's the 4th clutch packs that will be toast very fast when making decent power and in 4th gear
Thanks guys. Good to know.
