Suggestions for painting engine cover
Old May 5, 2013 | 10:13 AM
TMoney's Avatar
Default Suggestions for painting engine cover
I want to partially paint my engine cover, but not the whole thing. Basically just like this:
What would be the best way to do this? And is there a certain type of paint I should use?
Old May 5, 2013 | 10:30 AM
If I follow your pic, you want just the letting silver and the rest factory gray? GM did that from the factory on the earlier years of that cover. But by the time you find one in good enough shape the cost of paint would have been easier.
There are guys here that have painted there covers and can give better advice then I, ut it will take a lot of time masking.
OR, you can go to Welcome to Reflective Concepts and I believe they have overlays you can just stick that might be much easier to do.
Old May 5, 2013 | 10:40 AM
TMoney's Avatar
Yeah you got it I just want to paint the lettering. I thought GM did it from the factory too and I was surprised to find that mine was not painted
Old May 5, 2013 | 11:46 AM
iMuf's Avatar
I have done a ton of research on painting engine covers and what paint to get and what not. From everything I have read and heard from other people, the engine cover doesn't get hot enough to need high heat paint. So any normal dupli color paint or whatever brand you choose will be fine. Now I am painting my entire engine cover so it won't be exactly the same as what you are doing. but I sanded the entire thing down with 400g sandpaper and then I primed the entire thing and let it dry for a couple days. Then I went back and sanded with 600g sandpaper and as soon as I finished that I sanded with 800g wet sandpaper to help make it nice and smooth then I put on the base coat which for me was rid and now I just recently finished taping everything off and now I am waiting for good weather to paint all the letters and accents. and after that dries I will shoot it with clear to give it a good shine. Then I will cut the clear with 2000g sandpaper and then buff it to a really nice shine. For you, you will probably just need scuff up your letters and whatever you are painting with 400g sandpaper and then just tape everything off and start painting.
Old May 5, 2013 | 11:49 AM
You mean like this?
Clean it...prime it tape it off and paint it!
I used Duplicolor!
Attached Thumbnails Suggestions for painting engine cover-v__9789.jpg   Suggestions for painting engine cover-v__b6d7.jpg
Old May 5, 2013 | 12:15 PM
TMoney's Avatar
Originally Posted by STUMPMI
You mean like this?
I used Duplicolor!
Not like how you did, only the letters I want to paint silver. Thanks for the info though!
Old May 5, 2013 | 12:41 PM
the cover was grey....
i painted it black...
then the letters/etc with silver
Old May 5, 2013 | 03:16 PM
TMoney's Avatar
Yeah you're right I read that wrong. Just looking to paint the letters silver
Old May 5, 2013 | 04:23 PM
Take your time...Tape it off cleanly...
It should turn out great!
Franks 03SS
Sep 8, 2013 03:02 PM
labnjab
Feb 20, 2010 06:09 PM
TRMorrison
May 12, 2009 02:08 PM
Enzo354
FWD Tech Guides '95-'07
18
Nov 27, 2008 10:02 AM
kissmyss03
Oct 10, 2005 08:14 PM
