Weird Headlight Problem
Old 04-13-2011, 04:32 AM
XxRIDIN CHEVYxX's Avatar
Default Weird Headlight Problem
Recently my left low beam went out. So i start to replace it and find out that the lightbulb connecter is burnt and so its the connecter that runs to it. I figured that i could just splice the wires and put a new connecter and lightbulb. Once i finished that, the low beam and the high beam are on at the same time (just the left side). Even though they are both lit, they are very dim.
I have no clue as to why this is happening and was hoping to find some advice.
Isaac
Old 04-13-2011, 04:41 AM
MillerMonteSS's Avatar
2010 Monte Of The Year
Electrical problems are some of the hardest things to diagnose online... Would you be able to post a picture of the new connection along with the wires that lead to it? Welcome to the forum!
Old 04-13-2011, 05:46 AM
Isaac
Hi Isaac, is this on your 02 or 86 Monte ?
I think just replacing the connector is not the problem. You will have to check out why the first one burned `out.
Possible that your switch is bad, or a short in the wires.
Do you have a electrical tester..?, to check for shorts & trace the wires ?
Have you done any electrical mod's where other wires have been added ?
Good Luck 4-Sure.
Old 04-14-2011, 08:44 PM
theres no electrical mods... and i figured that the switch wasnt bad since the right side low and high beams work properly...
Old 04-14-2011, 09:15 PM
xxtheshockerxx's Avatar
RED DEVIL
what kind of headlight bulbs were you running?...i had this problem with my 03 monte
Old 04-14-2011, 09:26 PM
its just the stock 9006bulb
Old 04-14-2011, 09:52 PM
RED DEVIL
i had some cheap blue lights that ran on almost 100w and they melted my harnesses...now all i use is silverstar bulbs they run on 55w so no melting haha
Old 04-14-2011, 10:05 PM
mrl390's Avatar
GMs have had a problem with burning electrical connectors for years. First I have heard about the problem in a monte. Make sure the wires arent connected backwards just to be sure before you dig any further into the harness.
Old 01-03-2013, 06:14 AM
Old thread but I have the same problem what's the fix?
Old 01-29-2013, 04:49 PM
i would like to know as well my plug where bulb plugs in is burnt adn bulb wont light .where do i get replacement
gohawk72
10-19-2009 10:13 AM
skylark65
07-01-2009 03:13 AM
TX323GT
05-22-2009 10:00 AM
motivation2k3
09-29-2008 03:58 PM
motivation2k3
09-29-2008 08:22 AM
Quick Reply: Weird Headlight Problem
