Tranny flush and filter change!
Old 10-28-2005, 04:51 PM
04MonteLS's Avatar
Default Tranny flush and filter change!
I was finally able to locate a shop that does the pump inlet tranny flush and I recruited them to perform the task on my Monte, changing the filter at the same time. The dealer wanted $140 to do the service and they use the less than favorable cooler line flush, I got it done for $110 with the more complete and safer method.
The things I was noticing was that when I would slow down to say 10mph or less, from anything above 35mph, then accelerate, I'd get a rough/delayed engagement. Meaning I'd step on the pedal and maybe a second or two later I'd feel a rough engagement that was so blunt it would throw my head back a bit. Also, it wouldn't shift to 4th like it should all the time. It would hang in 3rd for a while sometimes.
After getting the service done I noticed it shifted alot smoother, but the real test was gonna be the acceleration from a slow roll after slowing from 35mph or more. I did it 4 times on the way home, my head didn't get thrown back once, nor was the engagement rough. I didn't notice it getting hung in 3rd either. So far so good It's amazing how much better it feels w/clean fluid and a clean filter.
Old 10-28-2005, 05:32 PM
Default RE: Tranny flush and filter change!
i used to do tranny flushes when i was a tech? what are the two methods being compared here?
Old 10-28-2005, 06:08 PM
04MonteLS's Avatar
ORIGINAL: Patrick
They're both listed in my original post, cooler line flush and pump inlet flush.
Old 10-28-2005, 07:32 PM
I really appreciate your advice Monte LS.[8D]
Tj
Old 10-28-2005, 07:40 PM
04MonteLS's Avatar
ORIGINAL: 03SSdriver
Tj
I don't have a clue what you're talking about, but thanks[&:]
Old 10-28-2005, 08:16 PM
[quote]ORIGINAL: 04MonteLS
Tj
I don't have a clue what you're talking about, but thanks[&:][\qoute]
I should have mentioned it was the difference in the tranny service methods.
Tj
Old 10-28-2005, 08:58 PM
04MonteLS's Avatar
ah, so you weren't being sarcastic. I thought you were trying to be a comedian.
No problem man
Old 10-28-2005, 10:27 PM
ORIGINAL: 04MonteLS
No problem man
Naaah. I'm here to exchange ideas and learn about the car.Have a laugh or 2.
I didn't think about the difference until you pointed them out. I'm going to get mine done soon and i'd prefer it done correctly.
Tj
00MonteCarloSS
09-05-2014 11:02 PM
DenaliZO6
04-13-2010 08:35 AM
tridski
03-01-2010 03:48 AM
ashleymc34
30
11-01-2009 10:03 PM
BD
05-04-2007 02:56 PM
Quick Reply: Tranny flush and filter change!
