Can't get HI beams on?
Hey guys, new the the forum. I have a 2000 Monte Carlo. I can't get the hi beams to go on. I pull back on the turn signal and there is no click or anything. When I pull back, the high beams do come on until I release the lever. At first I had then stuck on HI, but I pulled hard enought to get them back to LO. I pulled the plastic halves off the column and can see the turn signal switch. Is there anything I can do to fix this? Or do I have to replace the switch? Is there a relay someone that turns the HI beams on?
Thanks
Chris
Thanks
Chris
RE: Can't get HI beams on?
I am searching the internet for used multi function switches and I find 2 options. w/cruise and w/o cruise? The car has cruise, but not on the multi function switch (turn signal lever), it's on the steering wheel. So when it asks "w/ or w/o cruise", do they mean the car or the lever?
Chris
Chris
[align=center]Hi Chris,[/align][align=center]I think you need a switch like below,[/align][align=center]I searched for one for a 2000 Monte Carlo & could not find, but it has nothing to do with your cruise control. Do a Search for a AC Delco Turn Signal Switch.[/align][align=center]If you dont find, I will search more later, I have to get back to my studies : (
Good Luck from `Space
[/align][align=center][/align]
Zoom
[align=center][/align][align=center][/align]
2000-2005 Chevrolet[align=center][/align][align=center][/align]
"AC DELCO, TURN SIGNAL SWITCH OEM Design Turn Signal, Headlamp Dimmer, Windshield Wiper And Washer Switch And Lever, A High Quality Direct Replacement Part Providing Exact Fit For Easy Installation And Reliable Operation[/align][/align][/align][/align]
Zoom
2000-2005 Chevrolet
So the "w/cruise" & "w/o cruise" have nothing to do with the switch or wiring? One salavage yard said that the wiring was different even though the cruise control wasn't on the turn signal. I figured when it asked if it was for cruise or not, it was reffering to the lever not on the vehicle. Is the monte even offered without cruise?
Thanks
Chris
Thanks
Chris
LennyLeonard
11-15-2016 06:02 PM
6th Gen ('00-'05): Low Beams inop, have high beams...
svzpt71
05-11-2015 06:30 PM
