Can't get the tranny out of Park
Old 01-13-2007, 01:06 PM
desighitter's Avatar
Default Can't get the tranny out of Park
97, 3.1, Monte LS. Evidently the mechanism that locks it in park is out of adjustment or failing because it takes a couple of minutes and hard pumping on the brake pedal to get the thing out of park. Where is the part located that is the problem?
Old 01-14-2007, 08:41 PM
Default RE: Can't get the tranny out of Park
i believe its an electrically controlled solenoid that is switched by the brake on/off switch.. might want to check the switch or the solenoid in the shifter console is bad.
Old 02-05-2007, 02:53 PM
I am not sure what ranny you have in it... But in most cases there is a wire that come from the tumbler(where you put the key in the ignition) and it goes back down to the transmission to get the signal that it is ok to run. I had to run a "jumper" because i replaced allt he electrical compnents and it still didn't fix the problem completely, it was 50/50 if it would work or not, ran the jumper and spliced into the wire and it works perfect!
Old 02-06-2007, 03:19 PM
ORIGINAL: 1977Monte
There is a solenoid in the shifter to prevent it from coming out of park without pushing on the brake pedal. it is called BTSI (Brake Shift Trans Interlock) It is controlled by the brake pedal. With the ign on and engine off step on the brake pedal and you should hear it click when it is energized. Most likely problem is the brake switch but I have the solenoid replaced.
Maybe this will help.
www.autoshop101.com/forms/h18.pdf
peteygnyc
06-29-2019 02:04 PM
LennyLeonard
11-15-2016 06:02 PM
95mcarlodan
12-31-2014 02:00 PM
Gbrown
10-04-2009 04:59 PM
zk6216
03-22-2008 02:27 PM
Quick Reply: Can't get the tranny out of Park
