2004 monte carlo ls large evap leak
Old 06-10-2007, 07:43 PM
bud8gang's Avatar
Default 2004 monte carlo ls large evap leak
Have a large evap leak code. Was wondering if anyone had a link showing the evap system. Will be purchasing a new gas cap in the mean time to swap out. Hopefully this will be all. Although I am doubting that the gas cap is the problem. Tried listening for a leak back by the gas tank and under the hood but didnt hear nothing nor knew where to look. Any help appreciated.
Old 06-10-2007, 09:45 PM
wiz kidd's Avatar
Default RE: 2004 monte carlo ls large evap leak
that is most likely what it is, best to start with the cheapest and most common things
Old 06-11-2007, 12:03 AM
First thing i would check would be the pcv valve, check to make sure that it is working and that it has not come apart, check the hose that is going to the valve
Second
Somewhere under the hood should be a decal showing the vac. hose routing. This should include evap system.
Charleslatrelle
04-08-2014 09:26 AM
major1
11-01-2010 09:13 AM
shaboom5
06-03-2008 06:51 PM
jay26
MCF Website Problems & Issues
01-28-2008 03:41 PM
Quick Reply: 2004 monte carlo ls large evap leak
