6th Gen ('00-'05): 3.4 Engine - MagnaFlow CAT
I have a 2004 Monte Carlo LS with 3.4 engine.
- Has any used this CAT on a 3.4 Monte Carlo?
- Does this have the U-Bend delete?
I have not used that one, but pending the pic is correct, it has a U-Bend delete (you can see in one pic the bung for the O2 to go into). Since it's a complete downpipe with CAT, I would assume it deletes the U-bend (other wise they would have to put it back since the U-bend is part of the factory down pipe and this is a bolt on solution).
I vote, GO FOR IT!
BTW - Magnaflow is a common and trusted manufacturer for CATs. I see no issue there.
I vote, GO FOR IT!
Thanks for the replies. I was not sure if it the pic was correct and wanted to see if someone actually bought this CAT before. Never can trust the pic. I think this is a good price for this seeing as it is a complete downpipe with CAT. I don't know of any other downpipe that would be considered "highflow".... don't think there is such a thing..... unless you run a downpipe without the CAT...
For a 3400, I'm not sure anyone makes a DP with a high flow cat.... But there may be someone out there that does....
But this does not seem like a bad deal at all. Nice bolt in solution.
exhaust questions
I recently bought 2004 monte carlo ls I purchased a magnaflow cat back exhaust system, I wanna replace the factory exhaust system completely will I also need to purchase a catalytic converter & resonator to complete the install???
The entire exhaust system is comprised of (from engine back)
- headers w/ cross over pipe
- downpipe w/ CAT
- resonator
- muffler(s)
- tips
Here is what I found... is this what you bought?
MagnaFlow
· Dual CAT-Back Exhaust System à http://www.summitracing.com/parts/mp...el/monte-carlo
Any exhaust system that is called a "CAT back" is a complete replacement system starting at the connection of thye CAT (not including the CAT. If you want to replace the stock downpipe that has the U-Bend and stock CAT then you have the following options:
3400 Downpipes
Summit Racing
· MagnaFlow Direct Fit CAT à http://www.summitracing.com/parts/mpe-23433
Milzy Motorsports
· Economy Downpipe w/ High-Flow (T409 Stainless) àhttp://www.milzymotorsports.com/mms-economy-stainless-downpipe-for-3100-and-3400-powered-97-03gp-00-05mc-imp/
· Downpipe w/ High-Flow (304 Stainless)à http://www.milzymotorsports.com/mms-stainless-downpipe-for-3100-and-3400-powered-97-03gp-00-05mc-imp/
I have yet to install it. Below is where I purchased it.
Summit Racing
