Repair Guide: headlight issue resolution
Old 12-14-2014, 03:57 PM
Budsjlm's Avatar
Default headlight issue resolution
This should be the same 01-05
Had kind of a weird issue with my 01 after swapping from hid back to regular bulbs when one of my hid bulbs burnt out.
The issue :
Driver side headlight was dim and the high beam was on aswell but aswell very dim. The oassanger side headlight was on no differance in light output but the high beam was on very dimly.
Started with cleaning the ground that had no change,
Turns out it was a fuse so it is an easy fix
Driver side:
Passanger side:
The fuse spot:
It was a 15a fuse in the DRL/EXT LT Sit in the under hood fuse box,
Replaced the fuseand now I have proper working lights again.. hope this helps
Old 12-15-2014, 09:08 AM
Justin:
Great Find and thanks for the fix!
Old 12-15-2014, 07:39 PM
As always, thanks Justin for good write up. I've moved this into our Tech Guides section.
Zod642
41
01-27-2018 09:56 PM
TAV
04-20-2012 08:18 AM
Cowboy6622
01-06-2011 01:26 PM
nemesis
12-28-2009 09:29 PM
ramos87ss
06-05-2009 08:25 AM
Quick Reply: Repair Guide: headlight issue resolution
