Dex eats gaskets?
Old 03-17-2008, 07:52 PM
thomasnchy's Avatar
Default Dex eats gaskets?
Dex antifreeze eats gaskets? I read this here. Any opinions?
Old 03-17-2008, 08:49 PM
Default RE: Dex eats gaskets?
drain it out of the car
refill the car with water and a rad. cleaner(flush)
then add in a universal aint freez to replace it
problem solved
Old 03-17-2008, 11:10 PM
It's not necessarily the DexCool that eats the gaskets... it's that a system with DexCool that's not properly maintained will cause sludge, and eat away at gaskets...
I myself prefer the green, and switched to it back in 2005, and have been fine ever since.
However, if you check to ensure you do not have leaks, do not take on water or other contaminants (intake leak, slight headgasket leak, etc...), then your system will last a long time... improper maintenance of your cooling system, regardless of coolant will lead to issues down the road.
Old 03-17-2008, 11:27 PM
Dexcool is bad news for gaskets. I agree, Lav, improperly maintained systems will have much to do with this problem, however, Dexcool is supposed to be 150,000 mile coolant...definitely is not...lol. I advise everyone I know who has Dexcool to drain it and use a universal coolant. Before I did my intake gaskets, the previous ownerhad them done...the combination of using dexcool, and the gaskets being improperly seated killed those Fel-Pros. It's done right now...lol.
Old 03-28-2008, 05:08 PM
I just heard something about GM getting nailed for DexCool myself. I can't remember if their was a class action lawsuit or what the deal is.
Old 03-28-2008, 05:31 PM
Hey 04 Intimidator, take a look at this
https://montecarloforum.com/m_85529/tm.htm
Furder2010
04-29-2013 02:23 PM
mwjames
11-01-2011 06:54 PM
08-31-2011 08:01 AM
car addict
01-19-2011 01:37 PM
Flying Miss Daisy
12-20-2009 08:03 PM
Quick Reply: Dex eats gaskets?
