Engine turns over but won't start
Old 10-09-2011, 09:59 PM
Muddpupp's Avatar
Angry Engine turns over but won't start
Working on my moms 95 Monte carlo, r & r head gasket now car turns over but won't start. Need virtual mechanc plz
Last edited by Muddpupp; 10-09-2011 at 10:02 PM. Reason: Forgot year and make of car
Old 10-12-2011, 07:01 PM
3.1l? You just redid head gasket? Fuel pump turn on? Fuel pressure? Any other repairs or past problems?
Old 10-12-2011, 10:37 PM
double check all your wiring i believe there is a knock sensor on the back of the block that goes to the ignition module that i missed when i did mine. also make sure the spark plug wire are hooked up correctly
Old 10-13-2011, 07:10 AM
check the fuel system too.
Old 10-13-2011, 11:40 AM
nitehawkjcb's Avatar
Check all your grounds
Old 10-13-2011, 01:00 PM
Budsjlm's Avatar
start with the diagnosis
Do you have spark?
Do you have fuel?
SS-pacecar
04-02-2024 08:34 PM
z34phoenix
03-10-2014 11:32 AM
mohamie
04-15-2013 11:08 PM
BuRnTSpYdEr
01-24-2013 01:43 PM
ww
03-17-2007 01:50 PM
Quick Reply: Engine turns over but won't start
