coolant leak via upper bypass pipe
Old 06-26-2010, 04:34 PM
nycemsmedic67's Avatar
Question coolant leak via upper bypass pipe
hello, i have a question about replacing the heater hose bypass fitting comming from the lower intake manafold to a bracket holding the inlet and outlet heater hoses, and belt tensoner. its a 90 deg bend and in line. does the upper and lower intake manifolds need to come off to replace this pipe, or does anyone know a way to sneek it in? thank you for the help. Dave
03SSChevyFun
01-07-2015 11:28 AM
NYGiantsfan
06-17-2013 09:16 AM
01 Monte SS
10-23-2012 09:31 AM
jasonsmith
11-29-2011 11:00 PM
tjmaples
12-15-2010 09:44 AM
Quick Reply: coolant leak via upper bypass pipe
