wheel spacers
Old Jun 20, 2010 | 08:04 PM
Default wheel spacers
anyone know where i can get a good set of 20mm wheel spacers for the monte i wanna bring the back out flush
Old Jul 22, 2010 | 11:52 PM
albert1's Avatar
You'd have to look online, I just bought some 8mm off a parts store and they told me noone would carry any bigger because it's a liability and "illegal" .
Did you ever get to buy any?
Old Jul 23, 2010 | 09:25 AM
@albert> Do you have a pic of these installed? Is there a link you could give me or just let me know where you got them from, 8mm sounds like it would look pretty nice Thanks
Old Jul 26, 2010 | 03:42 PM
albert1's Avatar
I got them at a part store, they are made by cp automotive, and the exact size is 5/16 alluminum .
Theyr a universal part so they are not hubcentric, that's why i'm hasitant about intalling them, they were 14 buck for a pair.
I will post pictures tho.
Old Jul 26, 2010 | 03:49 PM
isnt 20mm huge? i think thatd stick out a ton
Old Jul 26, 2010 | 09:07 PM
2CM? About the same as two finger nails side by side. Lets say, >.........<
I think that would be a little on the big side. If I were to do with any, it would probably be about 5-7MM. Not anything that others would notice, just somthing I would notice. Maybe others that are also Monte Carlo enthusiasts would notice.
Ive never been one to like the wider than stock wheel base.
I dont see anything wrong with having 20MM (2CM) spacers though, if thats what you like?
Old Jul 28, 2010 | 12:14 AM
albert1's Avatar
So I bought some 5/16 (8mm aprox) spacers, and i got a hold of some steel 5 lug spacers 1/8th (3mm aprx) off the the junk yard.
With out any spacers the lug nuts after being torqued is flush with the lug bolt. after installing the 8mm spacer i noticed that it didn't turn as many threads as original 8 1/2 turns torqued. with the spacer the lug nut would only turn 3 1/4 turn, risky. So i try out the 3mm steel spacer and the lugnut turned 5 1/2 turns.
I decided that this was safer than my first attemps with the 8mm spacer.
I noticed the lug bolt, i think are the originals, dont have the treads to the full length of the bolt they stop at about a quarter of and inch before.
I may use the 8mm spacers if i can get a hold of longer and reinforced lug bolts.
but 20mm or 25mm spacers would look really nice i think, more flush
Attached Thumbnails wheel spacers-100_3164.jpg   wheel spacers-100_3163.jpg   wheel spacers-100_3160.jpg   wheel spacers-100_3158.jpg
Old Jul 28, 2010 | 08:31 AM
think you could take a pic from the front more and on the side. Get a better "overall" pic of it?? Thanks
Old Aug 2, 2010 | 01:51 PM
albert1's Avatar
I hope this is what you where looking for. let me know.
Old Aug 2, 2010 | 02:35 PM
yeah that rear veiw is better, but could you post a pic like in this angle>> Please and thank you much
I dont wanna bother you with it, I just wanna see it before I go and do it you know?
