What part is this.
Old 04-16-2012, 12:30 PM
Enzo354's Avatar
STILL SLOW
Default What part is this.
I asked my dad if he could get my back tire fixed while I was gone. Long story short he didn't ask me where to put the jack....
Can anyone identify this part so I can get a new one. I can't drive the car as is. It is the bent one towards the front of the car, on the rear tire. It's the bent, non adjustable rod.
Old 04-16-2012, 12:38 PM
What part in pic is bent???
#18 is ARM. Rear Axle Control Arm
ARM,RR SUSP TRAILING. Required: 02For: W (1997-2005)
#31 is <TABLE style="WIDTH: 100%; BORDER-COLLAPSE: collapse" id=ctl00_Content_PageBody_gridview_assemblyProduct s border=0 cellSpacing=0><TBODY><TR class=productKeyRow vAlign=top align=left><TD class=gridViewBorder align=center></TD><TD class=gridViewBorder align=center>10329691</TD><TD class=gridViewBorder>ROD. Rear Axle
</TD></TR></TBODY></TABLE>
Old 04-16-2012, 12:41 PM
lateral arm.
Old 04-16-2012, 12:56 PM
Mine was bent when i got it, i just bet it back cuz its a pita to remove IIRC the bolt hits the gas tank before itll come all the way out
Old 04-16-2012, 01:05 PM
Enzo354's Avatar
STILL SLOW
Thanks! It's #31. And I'll try to get out the bolt and see how it goes. If it hits I'll try bending it.
Old 04-16-2012, 03:45 PM
Oh that's a yucky bend
Old 04-16-2012, 04:17 PM
mrl390's Avatar
Like MonteMan said thats the lateral arm or control arm. I would just bend it back straight and then take it for an alignment. The toe is adjusted with the big nut on the rear arm so the should be able to even it out.
Old 04-21-2012, 05:04 PM
Enzo354's Avatar
STILL SLOW
I went under hoping our years were different, they aren't. How did you end up bending yours back?
Old 04-21-2012, 05:13 PM
I found a small bottle jack & wedged it up in there & used that to push it out
Old 04-21-2012, 06:15 PM
The only problem with bending it back is it will weaken the metal and may cause it to break unexpectedly while driving. Not saying I wouldn't try it, I did it to a tie rod once. It bought me some time but it still broke eventually.
Quick Reply: What part is this.
