What is best way to reduce wheel well?
how much would it be to lower it I'm talking springs, struts, and install? or do i need struts or just springs?
Woah woah woah.
Not just springs, you'll blow your stock struts extremely quick and ride like crap.
You're going to need struts, springs, anti-pogo washers and an alignment at the very least.
Well if you dont' care about safety you can just cut the spring or compress it like the Honda boys do.
But I recommend doing the strut/spring combo.
Here's a good, DIY combo that doesn't require spring compressors: ZZPerformance - Drop in Strut/Lowering Spring Combo #
Stock struts are not meant for springs that ride lower, anything over 10k miles on stock struts is getting lucky.
