What is best way to reduce wheel well?
Old Feb 10, 2014 | 03:55 PM
Dale_Jr_123's Avatar
Default What is best way to reduce wheel well?
I hate how i can see the wheel well on my monte, whats the best way to not see as much, but without lowering it to the point of scraping on everything? I want it to look good!
Old Feb 10, 2014 | 04:17 PM
Hiroska's Avatar
More rim / more tire / lowering <- Those about it. I hate it too, so I suggest maybe bigger rims, or if you like riding comfy, more beefy tire and lower it.
Old Feb 10, 2014 | 04:23 PM
how much would it be to lower it I'm talking springs, struts, and install? or do i need struts or just springs?
Old Feb 10, 2014 | 05:01 PM
l67ss's Avatar
Just need springs
Old Feb 10, 2014 | 10:55 PM
how much am i looking at for springs and installation you think?
Old Feb 10, 2014 | 11:00 PM
l67ss's Avatar
Seen them as cheap as $125 and as high as $600. Check out st theyre on the cheaper side
Old Feb 10, 2014 | 11:42 PM
Woah woah woah.
Not just springs, you'll blow your stock struts extremely quick and ride like crap.
You're going to need struts, springs, anti-pogo washers and an alignment at the very least.
Old Feb 11, 2014 | 12:06 AM
l67ss's Avatar
Took 35k miles to wear my struts out after i lowered it, and i dropped it 5". And they were rhe struts that came with the car
Old Feb 11, 2014 | 07:49 AM
Well if you dont' care about safety you can just cut the spring or compress it like the Honda boys do.
But I recommend doing the strut/spring combo.
Here's a good, DIY combo that doesn't require spring compressors: ZZPerformance - Drop in Strut/Lowering Spring Combo #
Old Feb 11, 2014 | 08:22 AM
Your 5th gen? I would like to see it dropped the apparent 5".
Stock struts are not meant for springs that ride lower, anything over 10k miles on stock struts is getting lucky.
