A warning to those considering larger tire sizes on 7th gen's
Over the summer I purchased a set of 18x9 Bullitt rims, and 255/45-18 Nitto tires. The rims themselves have a 34mm offset.
This being said, I noticed something had been cutting into the sidewalls of my rear tires. Thought about what could have caused it, and thought back to hitting a speed bump that came out of no where in an unfamilar part of town. I cussed and apologized to my car afterwards, but realized that in the inner fender well the rear body is just rolled in 90 degrees, and was the culprit. In normal situations, this wouldnt cause a problem, but where the speed bump snuck up on me and I hit it rather hard causing a lot of wheel travel, and thus the problem.
As far as any other clearance issues there are none, but I will definitely be taking my car to a body shop before putting that set back on once the weather is nicer so that I don't continue to tear up my tires, luckily the damages thus far are only cosmetic.
Just wanted everyone to be aware of the situation, hopefully I can save some a headache, or answer questions about that size of tire and rim combo fitting.
Good to know. I was wanting to put 255-45-18's on my new rims. They have a 40 offset. Whats your opinion on that? Is the 40 better or worse for me? What is the stock offset on the SS wheel?
Hi Dustin,
Thanks for posting & sharing your information about your problem. "We live & hopefully learn from the mistakes we make"
I hope that you can resolve the problem without to much expense....Good Luck
There are 3 types of offset: Positive, Neutral and Negative. Offset is measured from the hub where the lug nut holes are to the true centerline of the wheel. A positive offset increases the distance and moves the wheel further under the vehicle. Negative offset reduces the distance and moves the wheel further out from under the vehicle. With a neutral offset wheel the hub is aligned with the centerline of the wheel with equal distance on both sides if it.
A +40mm offset will place the face of the wheel 6mm further under the car versus a +34mm offset, so you will have more clearance between the wheel and fender well.
Yes, and exactly, I will be getting them rolled this spring, just the one thing I over looked when I checked everything out clearance wise after putting the new wheels and tires on.
6th Gen ('00-'05): new rims are in! tire sizes?
HIxArsenaL
Jul 9, 2013 11:26 AM
