tire sizes
Old Nov 13, 2007 | 01:11 PM
pitter05's Avatar
Default tire sizes
looking at new tires 4 my 05 LT lookin at going with lowprofile 225/50r/16 with an eibach lowering kit. Is there anything to worry about with that combo?
Old Nov 13, 2007 | 01:28 PM
Default RE: tire sizes
Hi Pat, & Welcome to the Monte Carlo Family
Sure hope you post some pic's of your Monte,
and keep us updated on your `mod's.
Before, & after Mod Pic's are a plus : )
Good Luck
Search the forum for Monte's that have done this,
or wait for a member to post their experience.
Good Luck.
Check out the below link on suspension/tires
(it's pdf format: )
Old Nov 13, 2007 | 02:18 PM
rchurch's Avatar
Welcome to the forum. I have an '02 SS with the eibach kit. I am running 255-45-17's and they fill the wheelwells up nicely. You can look at some pics in my profile. I thinkthe 225 - 50's will be too skinny and you won't be happy with the way they fit the wheelwells once you lower it. Just my $0.02. Good luck!
Old Nov 13, 2007 | 09:44 PM
pitter05's Avatar
what tire size would you recomend with the eibach lowering kit witch is 1.5 up front and 1.7 in the rear I am runnning a 225/60r/16 now just looking 4 a lower aggressive stance.
Old Nov 14, 2007 | 12:09 PM
04 Intimidator's Avatar
Hey Pat, welcome to MCF.
I just want to give you some food for thought here since you don't have your age posted and might not be looking at the grand scheme of things.
I'm all for lowering kits because they do look nice, but I also noticed you live in IL. You might not want to go with the lowering kit because you will bottom out more and are going to have more problems driving in the winter with snow.
I don't want to discourage you, but just want you to think about places you go, the steepness of driveways, ect. The kits are cool and look awesome on the Monte but I don't want you to drop $400 or whatever they cost just to hear you scraping everytime you leave the driveway.
Old Nov 14, 2007 | 12:23 PM
rchurch's Avatar
the 255-45's I'm running are about the biggest I could fit. The rear tires will rub slightly if I hit a bump with a couple of people in the back seat. Check out the tire manufacturer's websites and they'll have the spec's on tire sizes, such as width, height, etc. Also, if you are putting aftermarket wheels on, the offset will affect the fit. Check witht he people youa re bying from, but make sure they know what they are talking about. Sometimes you might get some kid who isn't that knowlegeble.
Ihave the same kit and the rear is a little lower than I like. You might consider going with the 1.5" in front and 1" in rear. It will make the car sit more evenly, maybe even slightly higher in the rear. It would be a more aggressive look, and might prevent the tire rubbing.
Old Nov 14, 2007 | 12:28 PM
rchurch's Avatar
One more thing - Imtimidator is right - you'll scrape on speed bumps and driveways and such, but mostly it's the plastic airdam under the front of the car and no damage is done. I have had what I assumed was the mufflers scrapewhile coming out of a driveway. I usually try to make sure I hit driveways and speedbumps at an angle instead of straight on to prevent scraping.
BrandonStebing
Sep 16, 2014 09:34 PM
HIxArsenaL
Jul 9, 2013 11:26 AM
DuSSt
Jan 18, 2012 11:41 AM
old chevy lover
Mar 20, 2007 12:40 PM
HaRvArDaLe
Nov 29, 2006 12:26 PM
